What did you do to the X today?
I missed that. I shrink-wrapped the EBPV connector and tucked it away in the harness, so it will have to wait for another "opportunity" to access it.
Sorry, I've done a poor - or more accurately, rather nonexistent - job of keeping up with my thread. I'll sit down and document when time allows.
My valley was almost as clean as yours, if only for a few days!
I got my harness rebuilt and put it back in before I left for Mexico and I has a miss on # 8 cylinder, buzz test sounds fine.
I put a ohm meter on the injectors from the IDM 42 pin connector and #3 and #8 had high resistance. after considerable thought and further testing I went back to my aerospace schooling and did a pin drag test, basically checking the tension on the female connector and sure enough #3 and * were loose. somehow either by putting weight on the harness during the turbo removal or when I removed the harness itself the female connectors got "bent". I ordered new pig tails from diesel Orings and will solder them in when I return next week. I did take the connector apart and crimped the female connector tighter and it fixed the miss. but I am not going to rely on that as permanent fix.
anyhow, check the tension on the valve cover harness and your glow plug connectors. take a male spade connector apart ( you want it flat not round like a paper clip ) and use the blade to insert into the female side and slowly pull it out making note of the feel of the tension. compare one to the other and you can feel a loose one. they make real gauges for this but a spade or other flat piece of the correct size works.
In the first pic, look to the left of the fitting - you can see the o-ring (blurry, I couldn't get the phone to focus on what I wanted it to) that was cut and got squirted out. Not sure how I missed it first go-'round, I had plenty of visual access and checked it at least twice. Anyhow, a couple hours rooting around in the engine bay and it is now leak-free. I'm glad I did my typical over-order of parts so I have spares, I had two HPOP rebuild setups. Gotta remember to order some more...
I am suppose to take a trip down to Southern California mid October and not sure if I will get it replaced by then. You think that is not a good idea with that broken leaf?
Tim M
Taking off the factory pinstripe using the 3M magic eraser. Middle of the pass door is giving me trouble. May have been an overlap area, not sure. Had to tape and use some 1000 grit to break it down a bit, still not gone. Looking at the rest of the stripe, many areas will be no issue at all, already faded and partially gone. Im really liking the look without it so far.
Mine has a random misfire on cylinder 8 if it sits for 3 or 4 days, I think it's moisture related, it goes away after it warms up. I still have 2 spare denso/motorcrsft cops, got to swap one in one of these days.
And I noticed the front passenger side caliper seems to be locking up intermittently. From what I remember from the last brake job the caliper was in good shape. I think I need to do a proper flush/bleed of the entire brake system.
And I found the culprit
Attachment 262057
Now to find the nearest store with a replacement caliper in stock.... fun day so far.....
Attachment 262057
And I have a nail or screw in my tire, and yes, it's leaking. Slowly though, it's been there for a couple weeks. But that'll have to wait for tomorrow.
I thought so too but they didn't come off easily as a cap would. I ran into my mechanic friend on the way to work this morning and he says that's normal, he sees them all the time and it's supposed to stay on. It's to mitigate damage to the piston. I guess these remans are real cheap and instead of replacing damaged pistons they are just covering up. Crap I hope it lasts a while.
Ex got a new windshield on Friday. Not because the original one was damaged, but because the glue had failed most of the way around. The only bit holding it in still was up the passenger A-pillar and about 10" across the top
It broke while trying to remove it the rest of the way which was pretty much expected.
