What did you do to the X today?
Old 04-13-2018, 10:56 AM
96firephoenix's Avatar
96firephoenix
96firephoenix is offline
Originally Posted by Oldguyfl
Here's a trick. Spray em of course, then BEFORE you try to loosen them whack the top of them with a hammer a few times. Jars the rust loose and they almost always come out. An old timer taught me that 40 years ago. Works 99% of the time.
How'd you think I got the other 3? lol. Looking at the remnants, the screw was mostly eaten through by rust. Only about 2/3 of the shank left.
Originally Posted by DavenTn
Replaced all the lines just recently supplied by https://sstubes.com/
dang... wish I'd seen this site before I got a kit for an F250... made it work, but the bends weren't even close to right for the intermediate line. axles and master to ABS were right on...
  #48062
Old 04-13-2018, 02:51 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Originally Posted by DeltaV
Give Etrailer.com a call. They will probably be able to help with the bolts. I was surprised to see the Curt rating on the hitch days 1200 tongue 12000 lb trailer and 1800lb tongue with WD. Didn't think they were rated for that much but glad it is.
Can you explain this a little better ? The sticker on my Curt hitch says 1,200lbs tongue weight either way. Where did you see the 1,800lb (wd) weight rating ? If you saw this on the hitch itself, or in literature you got with your Curt hitch ? If so, do you have a part number for the hitch ? I'd like to see if something has changed since I bought mine.
  #48063
Old 04-13-2018, 03:02 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Originally Posted by ArmyLifer
Since we’re still on the topic of hitches...anyone have a source for the 18mm bolts/nuts for the upgraded hitch? Fully loaded my TT tongue weight will be over 1000 pounds. I’ve read through a ton of older threads, but the part numbers mentioned are out of stock everywhere.
I replaced my factory hitch with a Curt, but used grade 8 3/4" bolts on mine with no drilling, even though they were slightly larger than the metric. Might be an option?
  #48064
Old 04-13-2018, 04:10 PM
DeltaV's Avatar
DeltaV
DeltaV is offline
Here you go
Part number still all nice and clean.
  #48065
Old 04-13-2018, 06:24 PM
IMASAP's Avatar
IMASAP
IMASAP is offline
Thanks ! Very interesting.... same part number as the one I installed two years ago, but rated for 600lbs more tongue weight. I will need to get an answer from Curt if any structural changes were made.
  #48066
Old 04-13-2018, 09:41 PM
Flyboy1100's Avatar
Flyboy1100
Flyboy1100 is offline
Nothing but got my new tires delivered today. Gonna try out Nokia Rotiiva AT Plus. If they are decent probably getting some nokian studded snow tires for my Subaru this fall
  #48067
Old 04-13-2018, 09:54 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Nokia tires are some of the best around.
I plugged my onboard trickle charger in just in case its low. Only moved it once in the last week and might want to drive it. But the last few days I've been driving the convertible since it's been so nice! 55f and sunny can't beat it!!
  #48068
Old 04-14-2018, 10:50 AM
Flyboy1100's Avatar
Flyboy1100
you hear that a lot, 674 shipped for all 4 in 265/70r18. Pretty good deal for E tires imho.
  #48069
Old 04-14-2018, 01:29 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,109 Likes on 560 Posts
I do believe they are tyres. Enjoy.
  #48070
Old 04-14-2018, 04:23 PM
loganj01's Avatar
loganj01
loganj01 is offline
Upgraded my brake controller. I've had this Tekonsha for a while but my Super Duty came with a good controller so I never installed it. Ex had a bottom of the line cheapo.
  #48071
Old 04-15-2018, 05:19 PM
Tbug05LTD's Avatar
Tbug05LTD
Tbug05LTD is offline
Changed the gear lube in my rear axle after break-in with the new 4.56 gears and TrueTrac. Used Redline 75W-140 NS which doesn't have any limited slip friction modifiers. Installed a Solid brand nodular iron cover. Unfortunately after finishing the oil change noticed the new pinion seal is leaking.
  #48072
Old 04-15-2018, 06:28 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,349 Likes on 1,755 Posts
Originally Posted by Tbug05LTD
Changed the gear lube in my rear axle after break-in ... Unfortunately after finishing the oil change noticed the new pinion seal is leaking.
What did you use for a break in gear lube?
  #48073
Old 04-15-2018, 07:04 PM
Tbug05LTD's Avatar
Tbug05LTD
I believe it was 85W-140 valvoline petroleum based.
  #48074
Old 04-15-2018, 10:02 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
It is a whole lot easier to remove the ABS sensor on top of the pumpkin and pour your gear lube in. Unless you like making a mess by adding it in from the side there.
  #48075
Old 04-16-2018, 12:49 AM
Tbug05LTD's Avatar
Tbug05LTD
Thanks for the tip Nicmike. It was actually fairly mess free as the tubing I used was such a tight fit in the hole that nothing leaked back when filling except at the end when removing the tubing.
Quick Reply: What did you do to the X today?
