What did you do to the X today?
I've been working on replacing all of my battery cables with upgraded ones and military style terminals while installing the new odyssey extreme batts.... got down to the starter connection which promptly pulled out of the starter. . Now waiting on the new denso to arrive so I can get the ol girl back on the road...
Also bought a cheap undercoating gun from amazon that came with tubes for shoving into holes and crevasses. Worked great. I'll post a couple of pics this evening. Going to rotate the tires, the weather is supposed to be nice.
This stuff. https://nhoilundercoating.com/
how much did you buy?
It only took a few of hours start to finish.
The Seat Shop also has videos on their site that take you through the process step-by-step. Not hard at all.
Im going to do more of the floor pan this summer. I may pull the tank and hitch and do everything above there too. Also get the hitch and tank cover blasted for powder coat. I'll install my new fill tube and check the pickup in the tank as well. I need to make this truck last a while. Once my building is done I can store it inside and keep it out of the salt.
Took the day off today. I was tired of the constant klunking under the front and back. I had put on new end links last fall, turns out they were junk, I guess I got what I paid for. I bought some new Moog sway bar end links and put them on last night, problem solved. Now for the rear, took of the air bags, they were leaking anyway never could figure out where they were leaking from. Took it fir a drive, much better but still something noisy back there. Took off the Hellwig, noise is gone. I have a nice quiet ride now, so much more relaxing. I installed some Timbrens so we will see how they work over time.
I will be spraying more areas before next winter hoping to have all critical areas covered. I plan on letting the rockers go another season without respray.
Next is either replacing the front doors or fixing the bottom. Not flapping in the wind but needs to be fixed.
@carbon coupe thanks for the photos. I think you talked me into buying some. I'll use the same gun I spray my bedliner with to apply the undercoating.
cleaned IAC, mostly for the heck of it. wasn't too bad, but very awkward to remove, installation was much easier.
swapped the other 8 coils, checked the rest of the plugs to make sure still tight, got brave and set my torque wrench to 28ft/lbs, most took a few degrees to make it click. still reporting 1 misfire on cylinder 9 i think from mode $06 data, still trying to figure that out. happens almost right away, then not any more.
i think at least one (#4) has been fixed before? not sure if it is just dirty looking or this is an insert? didn't scope the others, but I plan to check the torque on this one again in a few hundred miles
Could Have Been Worse
I didn't realize how lucky I was that this didn't happen on the highway!
It just sheared off at the base of the pitman arm.
Somebody was watching over me for sure.
Tied it up called AAA towed it to my buddies shop and called Ford and picked up all the parts.
Already had the Dual Steering Stabilizer setup which I was going to do this weekend, plans have a tendency to change.
After a few hours, I was back on the road including a front end alignment.
