What did you do to the X today?
  #43591
Old 09-25-2016, 08:18 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Originally Posted by CharlyG
Common sense in big cities along either coast is in very short supply.
BRake check in Arizona and you're likely to get shot. Most gun friendly state in the US !
  #43592
Old 09-25-2016, 08:20 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Originally Posted by SmackDaddy
Brake checking in Texas is a big no-no...��
ESPECIALLY when you drive a big truck and the person is driving slow in the fast lane....
  #43593
Old 09-25-2016, 10:31 PM
Jason Monea's Avatar
Jason Monea
Jason Monea is offline
Joined the "I need a new 6.0 oil cooler crowd"
  #43594
Old 09-25-2016, 11:38 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Well, I had mine in the garage with the hood up....
But luckily because it's a V10, the only reason for that is to change the oil.
  #43595
Old 09-26-2016, 12:30 AM
Blakshukvw's Avatar
Blakshukvw
Blakshukvw is offline
Whew, that's good. I thought you were gonna say your v10 shot a spark plug out of the head like v10's have been known to do
  #43596
Old 09-26-2016, 12:38 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Nope, I've only had that issue with my old '98 5.4 Expedition. Best part of the whole deal though? Even if it does spit a plug you are not stranded and it's a easy cheap fix.
  #43597
Old 09-26-2016, 12:48 AM
Blakshukvw's Avatar
Blakshukvw
Yeah the v10 I have experience with was driven 250 miles with a dead hole. I tried to fix the threads with the helicoil deal but that didn't work. Ended up dropping a new motor in the truck.
  #43598
Old 09-26-2016, 07:08 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Exactly. Unplug the injector and the coil and keep on driving.
  #43599
Old 09-26-2016, 11:57 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
For a spit plug? Sure helicoil sucks for this type of fix and only a threaded aluminum insert should be used (Time-Sert, Lock-N-Stitch, etc), but wow, you replaced the whole engine for one little 'ol spit spark plug?
Stewart
  #43600
Old 09-26-2016, 12:10 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
David,
Looks like the new owner is having a rough time.
another one to buy and fix russ! im liking your new trend of fixing excursions instead of destroying them like the past.
  #43601
Old 09-26-2016, 01:31 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Stewart
completely nuts
  #43602
Old 09-26-2016, 01:58 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
Stewart
Totally agree, seems an extreme measure for a failed fix using a less than correct insert.
  #43603
Old 09-26-2016, 02:00 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I mean worst case a new head, but a whole new engine...what the heck?
  #43604
Old 09-26-2016, 02:30 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
If you lack the experience timing an engine and dealing with head removal/install I can certainly see where replacing the engine would be "easier". Certainly still cheaper than a bulletproofing job on a 6.0 either way you go!
  #43605
Old 09-26-2016, 02:47 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Here we go again with the 6.0L bashing.
What did I do with my Ex this weekend? Drove it, didn't crack open the hood, didn't look under it just drove it.
Quick Reply: What did you do to the X today?
