What did you do to the X today?
Old 05-14-2015, 08:39 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
I got one of these upfitter switch panels and the adjacent mini cubby pocket.
If I sink it into the dash I have to loose the big cubby and pedal switch.
I think I want to figure a mount below the big panel to mount these then have the controller below that.
I want the 650 dash bad I just am not willing to ditch the cubby, I wonder if the stock big cubby could be mounted to the 650 dash where the above poster put his two gauges?
  #34952
Old 05-14-2015, 08:44 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,109 Likes on 560 Posts
Originally Posted by hav24wheel
I like the outcome. I was originally going to repaint the bumpers to stock color, and change to black plastics and black running boards. But went black bumpers instead for ease and not having to buy plastics. But the front bumper plastic has seen better days.
Now you need to give the hitch the same treatment! It will all look great together.
  #34953
Old 05-14-2015, 08:47 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
If you want to experiment, the plastic these are made from plastic welds nicely (I used some of the original lower panel to fix my dash holes)
  #34954
Old 05-14-2015, 08:50 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
I hope you realize them switches have tinny wires for them that run to a relay bank. The switches themselfs can't carry much current. Unless you got a kit like this. http://www.1aauto.com/2011-15-ford-u...duKxoCmPHw_wcB
That I do! That thing has most of the coating falling off. Lol.
  #34955
Old 05-14-2015, 09:03 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
I hope you realize them switches have tinny wires for them that run to a relay bank. The switches themselfs can't carry much current. Unless you got a kit like this. 2015 Ford F250 Super Duty Truck Upfitter Auxiliary Switch Kit (FORD) at 1A Auto.com
Yessir, they need to power up relays. The pins on the back make toothpick look huge.
  #34956
Old 05-14-2015, 09:31 PM
ChadTaylor's Avatar
ChadTaylor
ChadTaylor is offline
I think that looks great. What did you use for black?
  #34957
Old 05-14-2015, 11:03 PM
VTENX's Avatar
VTENX
VTENX is offline
Replaced a bulb in the gauge cluster.
Changed out the serpentine belt.
Last week I replaced everything in the front brakes except the rotors. (Which, btw, fixed my 4wd when I replaced the vacuum hoses!)
  #34958
Old 05-14-2015, 11:48 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
My little cousin graduated high school today, he drove the Oldsmobile. Very proud of that kid!
Also, Skip will be happy my dad's new wheel and tire package for his Corvette. 18x8.5" wheels with BFG G-Force comp 2 255/45 18's.
  #34959
Old 05-15-2015, 06:24 AM
2wdDezlX's Avatar
2wdDezlX
2wdDezlX is offline
I was considering that also, but to get the whole lower dash also. It has the drivers side glove box and could possibly mount the pedal switch inside it and still have more room than the cubby right now.
  #34960
Old 05-15-2015, 07:58 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Tomorrow!!
  #34961
Old 05-15-2015, 08:05 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
Originally Posted by nmclella
All lubed up and ready for reinstall. Worked like a charm, and I can now turn my hubs! Success. Won't be waiting 13 years for the next lube.
This also came in the mail today. Will install over the weekend.
Good job on the auto hub clean and lube Nate.
Tell use more about that USB thing-a-ma-jig, is that a dual USB plug in an actual rocker switch for them?
I like that two tone bumper look you have there Dave, the tan pads really set them off!
  #34962
Old 05-15-2015, 08:57 AM
Technologiq's Avatar
Technologiq
Technologiq is offline
I think I'm going to try and create a custom panel for the space at the back of the center console. Since I don't have a factory stereo and use wireless headphones I think I'd like it to house 4 USB, 1 110v and 1 12v adapter. Only problem is I have neither the materials or tools to do it
  #34963
Old 05-15-2015, 09:54 AM
nmclella's Avatar
nmclella
nmclella is offline
Tom,
It looks like a rocker switch, however it doesn't rock to choose whether or not it is powered. More of an aesthetic thing I guess.
I purchased it so I can stop using an inverter plugged into the 12v plug for my torque tablet and phone. Will get rid of some of the wires clogging up the front.
http://m.banggood.com/Waterproof-DC12-24V-Motorcycle-Dual-USB-Power-Charger-Socket-p-968172.html
Cheers,
Nate
  #34964
Old 05-15-2015, 10:04 AM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
well, it looks like the house buying deal I was about to tie up and start paying for, just imploded... I am now back on the market looking for housing with a lot less time than I had before to make things happen.
Oh, and the RECON cab lights I had put on my Ex, they suck! I mean they are complete pieces of crap!
I have two that have gone bad already (less than a year), and the only shinning light is that they are under warranty. What is even more frustrating, is that each light is a full assembly, so each one that goes bad, the whole thing has to come off, be unplugged from the harness and then a new one hooked up and bolted in place. there is no simple lightbulb replacement with their product. The design is utter crap!
In my opinion, everyone stay away from their stuff! I think I will be saving up to buy OEM cab lights and eventually switching them all out.
  #34965
Old 05-15-2015, 10:24 AM
nmclella's Avatar
nmclella
nmclella is offline
http://m.banggood.com/Dual-USB-Adapter-Charger-Cigarette-Lighter-Sockets-Digital-Voltmeter-p-949446.html
Not exactly what you're after, however you could swap out the voltmeter with a 110 volt and go from there. Very little fab required.
Also, cheap!
Quick Reply: What did you do to the X today?
