What did you do to the X today?
Old 03-18-2015, 09:02 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
I found it was mostly the cpvc to the fixtures (faucets, shower heads, and mixing valves) that leaked like the hoover dam. On my one mixing valve I had used the rubber washer the cpvc fitting came with plus tefllon paste, then a layer of teflon tape, then another layer of teflon paste again in order to get the bishes to seal.
  #33152
Old 03-18-2015, 10:23 PM
BigLouEx's Avatar
BigLouEx
BigLouEx is offline
Originally Posted by BigLouEx
What a pain in the a**. 7 broken to begin with, 7 more broke while removing. Only six behaved and came out like good little boys. Easy out didn't work. 8 had to have nuts welded on and removed and 6 had to be drilled and tapped. Replaced all with high grade bolts. Don't want to do this again. Two hours to remove brakes, rotors and wheel liner the night before. 16 hours the next day to work on exhaust manifold and 45 minute to replace brakes and rotors. Glad it's done, but boy do I owe my buddy with a well equipped shop!
Finally got round to finishing this years work. Drivers side wheel bearing hub and U joint. Should be good to go for another 15 years.
  #33153
Old 03-18-2015, 10:38 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
Originally Posted by Apocalypse
I'm working towards getting the entire house switched to cpvc. Some of the pipe in the house from the previous owners is 1/4 inch and the pressure is horrid. I have to get this place nice for my wife
I believe you're looking for volume with the larger size pipe.
I'm not sure if you are calling the bathroom a water closet and I had a hard time w the pic, but, my point is in Oregon you can't call a bedroom a bedroom unless it has a closet.
If making the bath large means taking the closet of a bedroom out and that adversely affects you home value it put good thought into it.
I don't envy you. We've done two pretty good makeovers on houses. I'm burnt out on it. FWIW out west plumbers don't use cpvc much anymore but they use an absolute **** ton of pex pipe.
  #33154
Old 03-18-2015, 10:51 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
The closet is for the entryway and doesn't connect to a bedroom (thankfully). I'm just worried that someone will see that as out of place and complain about it. Personally I would much rather have a nicer bathroom!
  #33155
Old 03-18-2015, 10:55 PM
Stebs's Avatar
Stebs
Stebs is offline
Use either copper or pex and ditch the cpvc.... As soon as I can afford it for my house, the cpvc is going buh-bye...
  #33156
Old 03-18-2015, 11:02 PM
Apocalypse's Avatar
Apocalypse
Well the first thing I have to do is figure out the flooring situation. Everyone needs to give me some direction so I can move forward on that or I'm going to be asking the guy at Lowes for help and I don't think he really gives a damn about my bathroom
  #33157
Old 03-18-2015, 11:04 PM
A Rodder's Avatar
A Rodder
A Rodder is offline
Put it in perspective by drawing out a floor plan if you can.
  #33158
Old 03-18-2015, 11:14 PM
Apocalypse's Avatar
Apocalypse
Good thinking
  #33159
Old 03-18-2015, 11:19 PM
Apocalypse's Avatar
Apocalypse
And here is the way the bathroom was set up when we moved in:
  #33160
Old 03-18-2015, 11:22 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Picked up my Expedition, very happy with the shop. Bringing them the '69 Cougar on Monday. Price came out very well and she runs like new!
Even gave it a quick bath afterword
  #33161
Old 03-19-2015, 12:14 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Pex.
Yup, pex.
I think you answered your own question then. Ditch the closet and make the bathroom bigger for the wife.
Stewart
  #33162
Old 03-19-2015, 06:37 AM
JuanHuevos's Avatar
JuanHuevos
JuanHuevos is offline
I'm still around...mostly
I made a boost leak detector. No immediate leaks found but pressure falls down pretty quick so the search continues.
  #33163
Old 03-19-2015, 07:01 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
Attachment 116360
Looks like you still have the vacuum lines hooked up. That may account for the rapid drop.
  #33164
Old 03-19-2015, 07:29 AM
JuanHuevos's Avatar
JuanHuevos
Are you talking about the red and green lines?
  #33165
Old 03-19-2015, 07:58 AM
Snowseeker's Avatar
Snowseeker
Yeah pex seems to be the thing now. If your gonna do the whole house buy the good tool and go to town.
In the north we always avoid putting the plumbing of anything in a cold wall. Because they don't take kindly to winter.
Quick Reply: What did you do to the X today?
