Axel Ratio ?
Old Aug 7, 2010 | 09:23 AM
pete17c's Avatar
pete17c
Axel Ratio ?
I working on a '87 F250 4x4 4spd w/302 (still SD, but w/ upgraded cam and LT headers) ..
currently have 3.55 gearing and 32" tires (235/85/16s).. unloaded starts were from second and with the creeper 1st I was happy with the pickup and pull from a start performance of the truck, before the motor upgrades ..
I can get deal on newer axles (from a '93 F-250) that are 4.10 gearing ..
what would I gain/lose performance wise? .. MPG wise?
TIA
Old Aug 7, 2010 | 09:34 AM
Conanski's Avatar
Conanski
Does the truck have overdrive? 4.10's are the right gearing for that motor but it will be a screamer on the highway if you don't have OD.
Old Aug 7, 2010 | 08:05 PM
pete17c's Avatar
pete17c
No OD.. 4sp w/ creeper 1st .. T18 maybe?
with the 3.55 set-up I was happy with the truck, using it for plowing my driveway and the miscellaneous load from the local lumber/supply house ..
.. I'm thinking I'll be towing a pop-up camper, including highway runs with some hilly terrain, when I get this together, but will still need to plow and make those runs to the home center for projects around the house ..
reading around and it seems MPG difference would be minor .. AXLE RATIOS
if I was to consider swapping the trans too, is there some thing better suited? (I don't do automatics )..
Old Aug 7, 2010 | 09:16 PM
Conanski's Avatar
Conanski
Yes... the ZF 5-speed from an F250, you retain granny low and get an overdrive ratio.
