Elec. Fuel ?
Old Aug 6, 2010 | 09:02 PM
fordpride's Avatar
fordpride
Elec. Fuel ?
Why can't you use the stock fuel bowl with a SD elec. pump in line like the SD
Old Aug 6, 2010 | 09:17 PM
Hussler's Avatar
Hussler
Stock fuel bowl is low pressure only, 5-7 PSI.
Old Aug 6, 2010 | 09:20 PM
fordpride's Avatar
fordpride
would the bowl crack or would the lid break frist
Old Aug 6, 2010 | 09:36 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I'm trying to think how you could set up the stock bowl w/ electric fuel, but part of the gain to electric fuel is getting rid of the stock bowl. the stock bowl doesn't flow all that great IMO. it wouldn't cost much to swap to filters on the frame rail either. Mind if i ask why your wanting to keep the stock bowl?
Old Aug 6, 2010 | 10:14 PM
fordpride's Avatar
fordpride
mainly because i just want prove it can be done
Do you think the pump could be placed to were it would pull fuel from the tank to the bowl then into the heads cause that's what i'm going to try tomorrow
Old Aug 6, 2010 | 11:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I don't think a Super Duty pump will suck the fuel up to the top of the motor.
They push fuel better than they pull fuel.
Old Aug 7, 2010 | 01:20 PM
fordpride's Avatar
fordpride
What would go wrong with the fuel bowl if i try putting it inline like a SD
Old Aug 7, 2010 | 04:58 PM
Dave Sponaugle
If I remember right, the SD pump puts out over 100 PSI.
The fuel filter lid on the OBS has almost 12.5 sq. in of area.
So that lid would have to hold over 1250 pounds of total pressure.
I don't see that happening.
Old Aug 7, 2010 | 05:01 PM
fordpride's Avatar
fordpride
so if we are talking just a lid or orings then IMO it's worth trying
Old Aug 7, 2010 | 05:17 PM
Dave Sponaugle
The lid and housing are what will see the high pressures since they have so much surface area.
100 PSI is not that much, but when it is on a large surface area those numbers start adding up fast.
Old Aug 8, 2010 | 06:58 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
The stock filter housing is not designed for that kind of pressure.
If you want to try it, carry a fire extinguisher with you and be prepared for a LOT more $$ in repairs if it does let go.
Is it really worth burning your truck to the ground in a blaze of glory to try to prove that an idea may or may not work?
I might sound extreme, but we're talking about possibly spraying fuel on a hot motor, and that's not something I would mess with. It might hold for a minute, maybe a month, maybe a year or 2. But IF it does crack the housing or blow the lid off, what then?
Just do it right the first time and don't worry about it.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 9, 2010 | 08:29 AM
Neal 97 250's Avatar
Neal 97 250
The bowl/lid will not hold that pressure. You will have fuel everywhere and I hope for your sake the engine is not hot.
Don't try it.
Old Aug 9, 2010 | 06:51 PM
fordpride's Avatar
fordpride
I've got it to pull trough the bowl at 60psi have not had time to do a full install yet
