EGR delete
Old Aug 6, 2010 | 07:41 PM
7.3 Rocket's Avatar
7.3 Rocket
EGR delete
First off I'm sorry for not using the search function feel free to yell at me for it if you like.
Now on to the point of the thread.
Our family business has a 2006 6.0L dually 4x4 that is a work truck for us. We have no need to turn it up any power-wise my father doesn't want a faster truck and my 7.3 is fast enough for me. We just want the truck to be as reliable as possible. It only has 32,000 miles or so on it but they're almost all either plowing or towing heavy this truck doesn't do much daily driving.
I've been told that the head gaskets on a 6.0 typically blow when something in the EGR goes bad and that by pre-emtively deleting the EGR system you can avoid blown head gaskets. Yes I know ARP studs are the best way but the truck will never be tuned and will likely have its factory cat for its whole life we just don't want blown head gaskets in it.
So my questions are:
1: Will deleting the EGR have any adverse effects on an otherwise bone stock truck? Do I need to get tunes for the truck for it to run properly without an EGR installed?
2: Will it, in fact, make the truck less likely to blow a head gasket?
3: Where would you get a kit to delete it?
4: What is the difficulty level to do it myself?
I work on my 7.3 all the time. I've done turbos, up-pipes, etc. on 7.3s but never more than routine maintenance on the 6.0 so I've got no idea how difficult it would be to do.
Thanks in advance.
BTW: I know the truck will not pass emissions without the EGR installed and is technically illegal but in Connecticut this truck will never see emissions testing or any type of inspection.
Old Aug 6, 2010 | 07:58 PM
Onus's Avatar
Onus
This has nothing to do with the egr delete but Gotta love the over 10000gvwr emission exemption in CT.
Old Aug 6, 2010 | 08:42 PM
BLADE35's Avatar
BLADE35
Thanks in advance.
I think that it would be great to deleat the egr sys that would get rid of all that soot and s*** that is going into the intake if you dont emiss test no problem id do it just waitin for mine to go out though will do the oil cooler as well if your going in that far. Is it blowing coolant into the intake or something y are doing the work?
Old Aug 6, 2010 | 09:20 PM
7.3 Rocket's Avatar
7.3 Rocket
Asking about possibly doing the work because we use the truck to plow and can't afford to have the truck down in winter with a blown head gasket like 6.0s seem to be famous for.
Currently no issues with the truck. Doing our best to keep it that way. I know EGRs fail and cause major issues. Trying to pre-emptively take care of any issues the truck may have.
Old Aug 6, 2010 | 09:32 PM
drtydsl's Avatar
drtydsl
you can do a egr delete kit without having to take the intake off. Rivercitydiesel.com, MKMcustoms.com are two that first come to mind that have good prices on the kit
Old Aug 6, 2010 | 09:51 PM
BLADE35's Avatar
BLADE35
if its ahead gasket your worried about you might want to think about arp bolts I think that most of the head gasket issues are from the bolts stretching from possible over boost to much boostwhen not warmed up fulley and possible programer issues and the list goes on im sure
