Turbo ?
Old Aug 6, 2010 | 05:11 PM
fordpride's Avatar
fordpride
Turbo ?
what kind of seal is on the compressor housing and can it be reused i need to change my compressor wheel
Old Aug 6, 2010 | 05:43 PM
plgebbia's Avatar
plgebbia
There is RTV or some kind of silicone in between the compressor housing, I don't know exactly what is used. I'm not an expert on turbo's, yet,
Someone will know exactly what to use!
Old Aug 6, 2010 | 05:44 PM
strokin'_tatsch's Avatar
strokin'_tatsch
You should be able to pull the compressor cover, change the wheel and throw the cover back on and be ok.
Old Aug 6, 2010 | 07:37 PM
fordpride's Avatar
fordpride
Thats what i needed to know thanks guys
Old Aug 6, 2010 | 08:11 PM
strokin'_tatsch
IIRC it should have an o-ring in there all the way around the compressor housing. If it doesn't then you will probably need Ford grey RTV. does the OBS turbo have RTV sticking out? last turbo i had apart was an SD turbo and it was an O-ring seal. If yours is o-ringed, DO NOT take off the o-ring b/c it won't fit right again after you take it off.
Old Aug 6, 2010 | 08:53 PM
fordpride's Avatar
fordpride
Have not taking it apart yet but no RTV sticking out
In between the compressor housing and backing plate there is a thin plate sticking out
Old Aug 6, 2010 | 09:40 PM
strokin'_tatsch
I will look at my turbo when i get off work Mike, but i'm pretty sure it's an o-ring like the SD.
Old Aug 6, 2010 | 10:16 PM
fordpride's Avatar
fordpride
I"ve been looking up rebuilds kit's and they all show a oring
Old Aug 7, 2010 | 08:37 AM
rideracelivemx7's Avatar
rideracelivemx7
the oring is from a previously rebuilt turbo, i got my kit from ron and my turbo had rtv, slammed the oring on there and didn't look back!
