Factory wheel size question
Old Aug 5, 2010 | 08:05 PM
Buckeye Rich's Avatar
Buckeye Rich
I have an 86 F250 2wd. It has the stock steel wheels with 235/85/16 tires. I saw a 91 or so f250 the other day with 265/75/16 tires. They look much better being an inch wider.
I think my stock wheels are 16x6. Has anyone run the 265s on a 16x6 wheel?
Thanks
Old Aug 5, 2010 | 09:39 PM
Franklin2's Avatar
Franklin2
I believe most stock rims on up through the later models are 6 inch. The only problem you might run into is the tire wearing in the center more than the outside because of the narrow rim. But I just sold a set of the Ford/Alcoa type tims with those size tires, and they didn't look like they where too wide on that rim.
Old Aug 6, 2010 | 06:48 AM
Buckeye Rich
Thanks Franklin2.
Anyone have any pics of this tire size?
Old Aug 6, 2010 | 08:12 AM
82F100SWB's Avatar
82F100SWB
I have run 265's on 16x6 wheels without issue:
The later wheels are 16x7 though, the Alcoas definatley are, and about 92 or so they switched the steelies over too.
Old Aug 6, 2010 | 11:13 AM
Buckeye Rich
Those look good...thanks for the pic!
