What does "Prioritzed" mean in the F-250 Order Process
I ordered a '11 F-250 PSD on March 6. After 4 weeks of hearing nothing, I bugged the dealer into calling the Ford rep to get a status. The rep said that it was "prioritized" and, if there are no parts shortages, it should be scheduled this week.
Can anyone tell me what that means with regard to actually getting the darn thing built?
Based on what I've read here, I'm figuring 2 weeks after building to have it delivered.
The dealer told me it would take 4-6 weeks to get the truck, but 4 weeks have passed and I'm just to "prioritized"! The dealer wouldn't speculate when I might get the truck, but said "the end of April" seemed "possible."
I'm not a patient man.
Not sure what "prioritized" means for sure but my best guess is an adjective used to make the dealer and customer think the truck is getting built soon.
I would be chopping at the bit to after waiting a month but they have two more weeks based on what dealer told you.
I think I would start calling Big Ford on a daily basis if truck not there by next Monday.
Can't wait to see pictures.
What trim level is it?
Oh Boy! Thanks for asking!!!!!
I spent weeks designing and redesigning this baby. It's going to be used to pull a 5th wheel trailer. F-250 King Ranch Crew Cab. Golden Bronze with Adobe and Adobe interior. 6-3/4' bed. 4WD. 6.7L PSD and 3.31 electronic locking rear axle. Power sunroof and rear window. Nav system with Sync and Sirius radio. Tailgate step. 5th wheel prep package. F/R splash guards. Roof clearance lights. Factory spray in bedliner.
I'm 51 but I feel like a little kid waiting for Christmas!
My understanding of prioritized is you have moved to the head of the line. But you mentioned if parts are available-from reading the KTP forums. the plant is shutdown this week because of parts shortages and may be shut down for another week in april for same reason.
Best of luck, I ordered mine on the 16th and mine is still in processing (as of last Friday).
best regards
Russ
best regards
Russ
I did a lot of research on that and from what I learned, the 3.3.1 with 18" wheels has equivalent torque to the 3.35 with 20" wheels. I ordered 18" wheels (both for economy of new tires and vehicle height), so the 3.31 seemed the way to go. The 3.31 also gets better gas mileage than the 3.35.
Sounds like you just ordered the same truck as I did. Mine will have the 20" tires and I didn't order the sunroof but most of the rest is a twin of yours. I chose to have the dealer send my truck into Line-X to have a colour matched spray in bedliner installed when it's delivered.
It will be nice when it arrives, If it ever arrives . I've been waiting since Feb 23rd to get my VIN number with no luck.....
I can't wait until X-mas also
I went to three dealers. Two wanted $500 and the one I picked wanted $1000. However, it's been 4 weeks and they haven't cashed the check. Go figure.
I'm guessing "prioritized" in this case means they have aggregated the orders from all the dealers and set the priority going into scheduling.
I saw your post on your order and I was hoping I'd have mine in 6 weeks too, but it wasn't meant to be. Sigh.
I'm also concerned over the height since I will sometimes drive it for business and need to park in a garage. With the 18" rims it will still be 6'8" high. That's why I got the sunroof, so I can look to see if I have clearance.
Ford shut down the Truck factory in Kentucky this week, so we're not going to see any progress.
http://www.csmonitor.com/Business/Latest-News-Wires/2011/0404/Ford-idles-Kentucky-plant-due-to-shortages?utm_source=feedburner&utm_medium=feed&ut m_campaign=Feed%3A+feeds%2Fwam+%28Christian+Scienc e+Monitor+|+Business%29
I believe all dealers set (or should be setting) their customer orders to priority 10. That's what mine was set at. I didn't get a VIN for quite some time and called my dealer and expressed my concern and impatience. There were others here that ordered after me that were getting their VIN's before I was so I knew something was up. Dealer claimed they had plenty of allocation. The owner of the dealer (it's a large dealer out here in Pittsburgh) called the local Ford rep and next thing I know, they pass off a document to me that reflects my order was prioritized and upgraded to Priority 1 and had a VIN shortly thereafter. Once the VIN was assigned and I had a build date, the process went fairly quickly. Time frames for my truck are below in my signature. Good luck!
The header on the document they gave me looks like the following (the body of the doc has every detail imagineable about the truck, much more than the DORA provided):
Ordering Dealer Name:
Ordering Fin Name:
Ordering Dealer Code:
Ship to Code:
Ordering FIN Code:
End-User FIN Code:
P&A Code: 07350
Region: 44
Order Type: X Plan
Order Number: XXXX
Production Week: Dec-06-2010
Allocation Week: 46-2010
Special Order Number:
Special Build Code:
Priority Code: 01
Plant Name: Ford Kentucky Truck Plant2
Price Level: 130
Invoice Date:
Purchase Order Number:
Emissions / Wind Tunnel Testing:
Fleet Incentive Program:
Route Code:
Sale Date:
Ordering Fin Name:
Ship to Code:
Ordering FIN Code:
End-User FIN Code:
P&A Code: 07350
Region: 44
Order Type: X Plan
Order Number: XXXX
Special Build Code:
Priority Code: 01
Price Level: 130
Invoice Date:
Route Code:
Sale Date:
