Keep or Bail?
Old Aug 9, 2010 | 02:05 PM
tex25025's Avatar
tex25025
Originally Posted by Spunkbrat
Thanks! I use the truck for towing only and it is not a grocery getter or do I baby it. I pull 4 horses up a 6% grade at 70 mph! Can't help that I didn't pull much last year as the economy was bad, diesel was $5 gal and I didn't go to many horseshows. Figured a vehicle could handle few miles without having to worry about the Venes (got repremanded in another post for wrong spelling) clogging up!
How long in between towing did it sit? Diesels really don't like to sit much at all(particularly the 6.0). I would suggest taking it out altleast once a week and romp on it after it gets to operating temp.
Your towing scenerio sounds good. The terrain that you type that you go through should be enough to help keep them clean, but if you do it once a month, irony is it's like you don't do it at that point.
I heard you about the economy, unfortunately, the truck doesn't know that the economy sucked. It's just like having a kid in some respects. Doesn't matter if you didn't earn as much this week compared to last, it still has to eat and drink and be taken care of. A lot of people don't seem to realize that about this new(er) diesels, either that or they don't care about it, and what they require. Now rather or not it should be like that, that's another debate entirely, but as far as the 6.0, that seems to be the way that it is.
Old Aug 9, 2010 | 02:51 PM
DSMMH's Avatar
DSMMH
Bought my 05 new, had the turbo replaced 3 yrs ago at 35,000 miles. Now, turbo needing the veins cleaned at 49,900 miles. I have a few questions.
1.) Will cleaning the veins solve problem or should I expect another issue soon?
2.) Any additives that can be used for the turbo?
3.) Should I cut my loses and trade up for a different engine 08 upward?
Hard because the truck is paid for....Thanks
Did not see this in your OP but I would change to SYNTHETIC oil and put a couple of cans of Seafoam in the oil. Take it out and drive it hard. This cycles the VANES (could not help myself, bismic) and with the synthetic oil and an excellent cleaner, like Seafoam, it should help. Sounds like you do a lot of sustained hard towing that keeps the turbo at high EGTs for long periods of time. If you use dino oil, it probably caused "coking" on the vane actuators causing them to stick and or the shaft bearing to possibly fail. Coking will not happen with synthetic oil.
Like you I put about 15,000 miles per year on my X and it sets sometimes for a couple of months since I primarily tow with it and drive it on long trips. No matter how long it sets, everytime I start it, within 10 to 15 seconds, my turbo sounds like an aircraft APU. I have instant turbo whine and response when I mash the GO pedal. I have never had any turbo problems or the turbo apart for any cleaning in 90,000 miles. I use Royal Purple 20W-50 synthetic motor and two cans of Seafoam.
DSMMH
Old Aug 9, 2010 | 03:54 PM
danocross's Avatar
danocross
DSM, do you add the 2 cans of Seafoam only at your oil change interval? And it is added to the oil?
Old Aug 10, 2010 | 07:56 AM
DSMMH's Avatar
DSMMH
Are you using dino or synthetic oil?
I add 2 cans of Seafoam when I change my oil. 13 quarts of oil and 1 quart (two 16 oz cans) of Seafoam. I also pour a can in the fuel tank at every other fuel fill up. As previously stated, never had a turbo or injector problem in 90,000 miles.
DSMMH
