1978 - 1996 Big Bronco
Four wheel drive?
Old Feb 13, 2003 | 06:53 PM
capearosa's Avatar
capearosa
Question Four wheel drive?
Have an 1987 Bronco II. Trying to find out full instructions for engagement and disengagement of 4x4 system. Thought it was just the shifter. But discovered Dial's on the front wheel hubs..................how to use - how to use...
Old May 21, 2010 | 04:27 AM
g_k50's Avatar
g_k50
Wrong part of site, you should be over in the Bronco II section. This is the Full size Bronco part. And I don't mean the early bronco section.
Just to clarify, check the owner's manual for proper operation of your truck.
Old May 21, 2010 | 08:47 AM
Encho's Avatar
Encho
The Southernmost Mod
Wow.... smooth g_k50, can't you see he's new?
First off: welcome capearosa. You probably don't have the owner's manual with you anymore, but you could search the net for it, there will probably be a .pdf around. Now, i think you should use the shifter, then get out the truck and engage the locking hubs. If it has Low Range, you'll probably have to place the transmision in Neutral before engaging it, the same when turning it off. There is a section of the forum devoted to Bronco II models, you can also ask there for better answers.
Old May 21, 2010 | 11:14 AM
Kemicalburns's Avatar
Kemicalburns
also dont use 4wd on dry pavement you will destroy the Tcase
I always engage the hubs then begin rolling and engage 4hi. if you wish to use 4low be completly stopped.
midsouth
18
May 8, 2014 05:50 PM
keisha9
2004 - 2008 F150
Jan 1, 2010 11:05 PM
oldfords4ever
Apr 20, 2006 10:21 AM
8 Lugs
Nov 6, 2002 01:05 PM
alf
1997 - 2003 F150
Feb 6, 2002 11:07 AM
