Would it be practical to tap into both heater hoses (inlet and return) for a higher flow rate instead of the tiny degass hose? I'm guessing the return heater hose is running along the firewall and Y-ing into the feeder hose under the degass bottle.
It wouldn't work well because when you select " max a/c" or "off" on your climate control, the flow to the heater core is shut off by a vacuum valve. Look under your hood and you will see the valve in the heater core hose beside the oil fill tube. Have someone inside the truck turn the dial to max a/c and watch the valve slowly close off the flow.
The coolant filters tap into the supply side of the heater hose before the climate control valve to feed the filter. I was wanting to run the larger diameter return hose and Y it into the return hose from the heater core right under the degass bottle. Would this still effect the climate control ? It seems like it should work and give a higher flow rate thru the filter.
I see what you mean now. I guess it wouldn't matter that nothing is coming out of the heater core if you wanted to tee into that hose with your filter outlet line. It would just be pouring into an empty hose. I don't think it would improve flow because flow is mostly limited by how much volume you are putting into the filter and the restriction inside the filter itself.
It won't flow more. Next time you have a filter in your hand, check out the discharge hole in the top. The Baldwin filters have a 5/32" hole, that's all. That is your limiting factor on flow. If you want to experiment with more flow, you could drill out a filter. Doing so crossed my mind when I first saw the filter.
Sorry for the hijack, but Bill that picture looks like it was taken in my neck of the woods, near Lake Arrowhead.
I think the biggest limiting factor is pressure differential. To achieve flow you need a pressure differential. you will not get any flow in the bypass if the inlet and outlet are tapped in the same hose regardless of whether the a/c valve is open of not...
The reason your tapping from that hose to the degass bottle is that those two regions have the largest pressure variation. You are limited by the pressure difference between the coolant manifold and degas bottle I don't think increasing the hose or filter sizes will help much...
I see what you mean. I have not bought a filter yet. I see the coolant filter on my Kenworth all the time it has a 1 inch hole on top and I assumed the Baldwins had at least a half or 3 quarter inch outlet. I would like to fit one of those monsters under the hood. The filter alone holds 5 quarts. You could filter the entire system in 5 passes !!
When you say the same hose do you mean the one hose going to the heater core ? Because I am referring to the 2nd hose exiting the heater core which runs back over and under the degass and hooks to a Y fitting which is the main outlet hose for the degass. I was thinking about taking the Y fitting off which serves as a 3 way and putting a 4 way fitting in. But then again a larger coolant filter would be needed to get more flow if the baldwin filters outlet is only 5/32"nds.
I understand where you are talking about, I'm just saying that I think the pressure differential is much more limiting than the size of the hose... You might double or triple the hose/filter size and see little difference in flow. I would encourage you to try it though... let us know what happens, I could be out in left field on this. Maybe the increased hose size will make a difference.
I've never seen a Kenworth filter, but I'll bet the coolant passage is not 1". The threaded attachment may be, but I doubt that the coolant passage is that big. Obviously I could be wrong. But on the common dieselsite.com coolant filter, the attachment is 3/8 NPT, and below that is a stamped metal hole that is very tiny - 5/32". That little hole is the most restrictive point in the entire system.
The point about pressure differential is a good one. The heater supply hose comes directly off of the coolant pump. The greatest flow through the coolant filter will be when the engine thermostat is closed, and the heater control valve is closed. At that point all the coolant pump output is directed through the oil cooler, EGR cooler, and the coolant filter. When the heater control valve opens, most of the flow will go through the heater core. Then when the engine thermostat opens, even more flow will be sent to the engine cooling circuit. However, considering the small size of that hole, I think there is always more than enough flow to keep it fully supplied with all it can flow.
Agreed on the heater hose being on the outlet side of the water pump and the degas return is on the radiator/suction side of the pump thus the differential.
I'm letting my thoughts overload my brain but I wonder if the reason for the tiny outlet hose going back to the degass is so the filter won't overfill the degass. I did notice while doing a coolant flush the degass would take its time pulling down the coolant. After the flush is when I discovered casting sand and floating particles !!!!! I will not even drive my truck until I can figure out what to do about installing a filter !! I was going to order one but fabricating a higher flowing filter using a base off of a 18 wheeler and tapping into those two heater hoses came to mind. OVERKILL ? Probably but this should have been a priority for FORD since the first diesels came out in the 1980s !! I went thru a lot of water pumps on my 1985 6.9 632,000 mls.! I'm beggining to see why.
The very essence of a bypass filter is that it diverts a small amount of coolant through the filter, without ever compromising the proper funtion of the original system.
I think the Baldwin filter itself could use a little larger passage. I might do some comparison with the Napa product when I need filters. There is no way the hoses are a restriction. So don't worry about it.
