351w tune
Old Aug 3, 2010 | 11:53 AM
jimford1's Avatar
jimford1
351w tune
Hey guys. I have a 68/71 ford f100. The engine runs smooth as heck but bog down when I gun it. Black smoke comes out of the exhaust on start-up too. It is a stock 4v 351 with a performer intake and a edelbrock 600cfm carb. I tried a carb spacer, it didnt work very good. I felt like it would have if I would tune the carb. Now it misses a bit at idle too. I want it to run great!! What do u think???
Old Aug 3, 2010 | 09:45 PM
jimford1's Avatar
jimford1
Seriously know can help?? WTF!
Old Aug 3, 2010 | 09:58 PM
Conanski's Avatar
Conanski
So tune it, black smore means it's running rich so start dropping jets until it doesn't do it anymore.
Old Aug 4, 2010 | 05:04 AM
Old Hickory's Avatar
Old Hickory
If you have black smoke at start up, check to make sure the choke is set corectly and
that the idle mixture is set correct. Use a vacuum gauge for the idle mixture adjustment.
If it bogs when you punch it and you have black smoke then too, the fuel enrichment
circuit should be checked. I don't know much about how to adjust an Edelbrock carb
but the functions are the same on most carbs. Get a copy of the instructions that
came with your carb. They should have some good info on tuning or go to Edelbrock's
website.
Old Aug 5, 2010 | 07:31 AM
jimford1's Avatar
jimford1
Thanks old hickory. You were a great help. Conanski, I needed to get pointed in the right direction. If your gonna be a jerk dont post. Its as simple as that. BUT I have read some of your smarta$$ comments before and they are pretty funny. I have never tuned a edelbrock before. My father used to tune my carbs by sound. But that isnt possible anymore. Thanks guys!!!
