rotor removal?
Old Aug 2, 2010 | 08:50 PM
ravens fan's Avatar
ravens fan
rotor removal?
how do i remove my rotor to replace my studs? do i need to take the whole inner hub out? thanks
Old Aug 2, 2010 | 09:51 PM
sconut1's Avatar
sconut1
2WD or 4WD? What year? Manual or Auto lock hubs?
Old Aug 2, 2010 | 10:00 PM
ravens fan's Avatar
ravens fan
its a 91 4wd manuel lock hubs
Old Aug 3, 2010 | 05:34 PM
eli85's Avatar
eli85
Yes you will need to take the hub out, then you will need the four wheel drive wrench to take the spindle nuts off. there should be two of them with a locking ring in between them. once you get them off the rotor should pull off, but be carefull because the bearing are coming with it. while you have it apart i would recomend that you get a new seal and re pack the bearings. hope this helps
