electrical prblem
Old Feb 13, 2003 | 10:28 AM
cwpitman's Avatar
cwpitman
electrical prblem
when i turn on my headlights or turn signal all my gauges go crazy,where is the best place to start to find the problem
Old Feb 13, 2003 | 01:31 PM
Franklin2's Avatar
Franklin2
electrical prblem
There is probably a common ground to the dash cluster that has a bad connection to the metal part of the dash. What I would do is take the cluster out, take all the connections apart and clean them with a pencil eraser, and put it all back together. Along the way you might clean or tighten something that was loose.
Old Feb 14, 2003 | 03:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
electrical prblem
Smear some silicone dielectric grease on the connections to keep them from corroding again.
