My truck won't run properly when I give it gas as the advance is likely shot, otherwise it runs smoothly in idle and if I gas it really slowly it will run OK. It has the hard line threaded on to the advance, but does anyone one know what vacuum advance will work on a distributor for a 262 engine? I don't mind cutting the hard line and putting a vacuum hose on it.
Is the distributor for a 223 or 300 the same as 262? Is there an after market distributor that will work as well?
