Sponsored by: Real Truck
suggestions please
Old Aug 1, 2010 | 02:48 PM
ayden2004's Avatar
ayden2004
suggestions please
Hey guys,
threw a 3 month old universal this morning. at 50mph. lots of fun. anyway when it went it apparently slit a tire as well (haven't quite figured out how yet) i did find a piece of a small trucks leaf spring in the road about where all this happened. could be that did the tire in or is it possible it did both the tire and the u-joint. my real question is i have looked around under the truck things seem like they are all in one piece but should there be specific damage i should be looking for. there was no warning that this u-joint was going bad. no vibration no thumping or any such symptoms. so what would you guys be checking if it were you? here are some pics
[IMG]file:///C:/Users/Anthony/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Anthony/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Old Aug 1, 2010 | 02:51 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Was it vibrating after you put the u-joint in, or did it just let loose? did you put the u-joint in, or did you have a shop press it in for you? Do you notice any marks on the driveshaft (indicating they put it back in the same way) if a shop did it? So many variables.
Old Aug 1, 2010 | 03:04 PM
ayden2004's Avatar
ayden2004
it was put in by a friend. it was put back in properly (i double check everything after work is done) there was no vibration since replacement. again no warning whatsoever just find it odd that it just let loose out of nowhere.
Old Aug 1, 2010 | 03:16 PM
ChargersFanInCO
me too in that case...no clue, man.
Old Aug 1, 2010 | 04:29 PM
senix's Avatar
senix
If it was put in and the driveline was placed in the same spot, it is just one of those things.
I'd check the driveshaft to ensure it is still true.
Old Aug 1, 2010 | 04:51 PM
BigPigDaddy's Avatar
BigPigDaddy
Those pics are too small for me to see much, but it is possible that the road debris caused the u-joint failure as well as the tire damage.
Old Aug 1, 2010 | 08:05 PM
ayden2004's Avatar
ayden2004
if you would like a better view of the pics you can go to Picasa Web Albums - Anthony - Truck thanks for your suggestions so far
Old Aug 2, 2010 | 06:58 PM
ayden2004's Avatar
ayden2004
so i've ordered my new tires. and picked up a new universal with the universal straps/bolts. would like to check for balance on my driveshaft but can't be without my truck for over a week. anyone know a way to check the balance without sending it out. (no place local does it they all ship them an hour away)
Old Aug 2, 2010 | 07:06 PM
senix's Avatar
senix
Only way is gonna be to roll the thing.
Old Aug 2, 2010 | 07:32 PM
BigPigDaddy
Second that motion. By the way, what is up with the blue tape on the u-joint in the pics???
Old Aug 2, 2010 | 09:46 PM
ayden2004's Avatar
ayden2004
the blue tape was to keep the caps on during installation.
so the new u-joint is in now just waiting on tires and i can see how the driveshaft faired from all this..... thanks again for all the suggestions
Old Aug 2, 2010 | 10:06 PM
redford's Avatar
redford
FTE Leadership Emeritus
I'm guessing the leaf spring you found caused this.
The only thing I would check is to make sure that your drive shaft slip joint spline isn't bottoming out for some reason, putting abnormal pressure on the U-joint. You'd see evidence on the nose if it did bottom out.
