zf s542 length
Old Aug 1, 2010 | 11:56 AM
daver's Avatar
daver
zf s542 length
Do any of you know how long the zf s542 with the 4x4 tail housing is? I'm putting together some fitment numbers on a M-c6 swap to a 351W zf and can't find info on how long that bugger is. I'm sure it came in some of your trucks.
Old Aug 4, 2010 | 01:19 PM
stick shifty's Avatar
stick shifty
trans length
26 1/4 case length. out of truck, sitting with tail up and bar across rear where transfer case would bolt to. trans is for 460.
Last edited by stick shifty; Aug 13, 2010 at 05:05 PM. Reason: remeasured due to gasket
Old Aug 4, 2010 | 03:04 PM
stick shifty
351w case
im suppose to pick up one for 351w this weekend, ill let you if different.
Old Aug 5, 2010 | 07:20 PM
daver's Avatar
daver
Thanks guys I'll look forward to hearing from you. A guy responded to one of my other posted requests and said the small block with tail to 4x4 was 29 5/8" sure hope so, that means the swap will be 7/8" - longer than original set up.
Dave
Old Aug 13, 2010 | 04:41 PM
stick shifty
351 zf length
got that trans Thursday, it is 29 inches even. i measured twice. again, i had a bar across the transfer case mount so my tape was straight.
Old Aug 13, 2010 | 04:55 PM
stick shifty
zf length 2
just went and measured small block zf trans on a angle, 29 1/2 in one place, 29 5/8 at another. should measure squared.
Rustyol79
Apr 9, 2017 07:37 AM
Squirrel Man
16
Dec 6, 2016 10:57 AM
PRIMERED79 SHORT BED
54
Mar 20, 2016 06:16 PM
BaronVonAutomatc
Aug 17, 2015 06:51 PM
Natcox012
Jan 25, 2015 10:23 AM
