Powerstroke A/C help!
Old Aug 2, 2010 | 11:57 AM
RRranch's Avatar
RRranch
It's screwed into the side of the receiver dryer on the right rear corner of the engine bay. By the evaporator. It has a schrader valve under it so you can replace it without blowing the charge.
Little known about them but they are adjustable. I'm not too comfortable saying how since the OP seems to have a low charge to me.
95bigtime's Avatar
95bigtime
Originally Posted by blueovalbigblock
Hey guys i will post this in the other forum for these trucks but i am having problems with my a/c and need whatever help i can get! so my a/c is charged and it blows cold as ice and everything but my clutch isnt coming on. at first i could wiggle the pigtail on back of the compressor and it would kick on but now i cant ever get it to come on. i took out the shim in the clutch and still nothing. finally i took the wires off and tested them with a voltmeter and they arent getting power with the a/c awitch on or off. any ideas what to do next or how to fix it?? its like 100 degrees here all week and im dying!! thanks!
If the ac came on when you would wiggle the plug I would start with checking for corrosion at the plug and clutch. Make sure the wires arent broken at the edge of the plug. then i would check for voltage at that plug-both inside the connector and a few inches back. if there is corrosion inside the wire it is very possible that you will get 12v inside the plug but not enough power to engauge the clutch so I would def use a test light and not a meter to check. If no voltage there then check the plug at the low pressure switch to see it you have 12v. If you unplug it you will only have 12v on 1 wire, if it is plugged in and the lp switch is good you will have 12v on both sides. If you dont have 12v at the plug then it is either a selector switch or a bad wire between lp switch and selector switch
Old Aug 2, 2010 | 11:21 PM
blueovalbigblock's Avatar
blueovalbigblock
okay sorry i got confused what the lp switch was i thought it was the one on the back of the ac compressor. so i will check the one that is actually is tomorrow. is rechargeing the system something you can do yourself?
Old Aug 12, 2010 | 11:05 AM
Muktown's Avatar
Muktown
yes you can recharge it yourself its very easy i just did in on my pos sunfire and im having the same problems your are with my truck and i think its low on charge. with 230k on it its very possible. of course wisconsin is the only state where 134a is illegal . so i have to go to illinois to get more freon
Prof100
Sep 29, 2016 10:49 AM
banks0531
Jul 10, 2016 02:07 PM
1998Ranger25L153CID
Mar 16, 2016 05:18 AM
R.J.M.
16
Oct 2, 2011 08:50 PM
runasoft
16
Jul 29, 2004 11:14 AM
