Axle Code
Old Feb 13, 2003 | 08:40 AM
RisingR's Avatar
RisingR
Axle Code
Does anyone know what the axle code found on the door jam means? All my shop manual says is that it is the axle code, which I think is pretty obvious since it says "axle" right next to it. Mine says 19 and two other buddies say 17 and 18. Thanks
Old Feb 13, 2003 | 11:04 AM
PHS79's Avatar
PHS79
Axle Code
I know that code 18 means that the truck has 3.08 gears. I don't know what the others are. Hopefully someone else can help out. Paul
Old Feb 13, 2003 | 02:46 PM
SPROCKET's Avatar
SPROCKET
Axle Code
17 — 3:31, non-limited slip
18 — 3.08, non-limited slip
19 — 3.55, non-limited slip
26 — 3.73, non-limited slip
27 — 3.31, non-limited slip
H9 — 3.55, limited slip
B6 — 3.73, limited slip
Old Feb 13, 2003 | 04:37 PM
offroadguy's Avatar
offroadguy
Axle Code
does anyone know what b9 is?
Old Feb 13, 2003 | 04:48 PM
RisingR's Avatar
RisingR
Axle Code
Thanks for the info. Why are 17 and 27 the same?
Old Feb 13, 2003 | 06:24 PM
steve83's Avatar
steve83
Axle Code
B9 is a LS, but I don't know which axle or ratio. A letter as the first digit always means LS.
17 is a 1/2-ton axle (8.8" or 9") and 27 is a heavier axle (probly 3/4-ton).
Old Feb 13, 2003 | 07:14 PM
offroadguy's Avatar
offroadguy
Axle Code
i was reading on the net and i found out that the b9 is a 3.55 LS
Old Feb 13, 2003 | 10:01 PM
Chas1234's Avatar
Chas1234
Axle Code
What years do these codes apply to?
Jon
