Fuel injectors?
Old Jul 31, 2010 | 10:03 PM
pstroker's Avatar
pstroker
Fuel injectors?
I have a 2002 4.0sohc explorer which swallowed a valve I purchased a complete motor from a 05 mustang (4.0sohc as well) I swapped the intake, exhaust manifolds,water neck,injectors (the injector plugs were different) upon start up with only 1 vacuum line missed it started right up up nice but has a miss.
number 5 and 6 cyl seem to be dead they both have 125 compression,spark from the coil pack and @ the new plugs,I checked the injector plugs and seem they were snapped in place.while running if you remove either plug wire #5 or 6 theres no change in motor tone ( I know this is a primitive test however im an old out board mechanic and we used to use this method lots for diagnostic purposes) if you pull of plug # 4 the moter stalls so looks like thats the only one working on that bank. could it be 2 bad injectors side by side any advice is appreciated ..
Old Aug 1, 2010 | 12:18 AM
97ExpGuy's Avatar
97ExpGuy
If I've read everything correctly, I believe this needs to be posted in the Explorer section of the forums. No biggy! I will report this to a moderator and ask to have it moved so you don't have to retype.
Here's the Explorer section:
Explorer, Sport Trac, Mountaineer & Aviator - Ford Truck Enthusiasts Forums
