low fuel pressure could do it, as could low oil level...
The oil level is fine. I just had her check the level. I'd check the pressure on the schraeder valve, but its not something that she'd know how to check. I'm hoping she can give me a good idea of what is leaking, but its been raining there the last two days, so i can't tell until then.
So next series of possibilities includes low fuel pressure to the fuel bowl, low oil level, and low oil pressure from the HPOP?
So, an electric fuel system, a T1/adreneline pump, and an oil change should fix this, right? Small problems are the best excuses for major upgrades... If only I was home to do them.
