351W megasquirt
Why???
a stock 5.8 should run fine on speed density efi or mass air efi. also there are resistors that you can get to make the egr and other smog equipment not cause a CEL and allow the motor to run fine. Ford Fuel Injection has them.
also that year wouldnt need or event talk to a VSS thru the computer thats an 89+ feature and was for the E4OD tranny to shift properly. has nothing to do with how the motor runs.
Eh.
Avoid MS1, go MS2. I tuned a Mustang with an MS1 that DIYautotune configured and sold to a friend for his 88 Mustang. The coil dwell control is a joke, the only combo of dwell settings that allows the engine to rev past 5100 rpms is HEI 4 cyl, but that setting doesn't allow sufficient dwell while cranking for the engine to start. A proper setup allows dwell to be tweaked with respect to multiple points in the rpm (frequency) band as well as multiple points of battery voltage.
I'm not hugely thrilled with the non-standardized approach the MS crowd takes to everything they do. Some of it works great, but a lot of it leaves you screwed if you own a speshul case vehicle. In the MS world, that means anything that's not a Miata.
Really, the best route is convert the truck to MAF and tune that. That's easy for me to say since I have all the gear, which would cost you over and above your MS budget. Admittedly while Ford MAF isn't hard to tune it's a little more involved for a n00b than a simple speed-density system with a vanilla VE table and some temp corrections.
Whatever you do, good luck!
mary-kate
37
03-09-2018 11:00 AM
jnye6625
05-08-2011 06:31 PM
4tl8ford
89
09-30-2010 01:01 PM
mattri
07-09-2007 03:07 PM
