speedometer need help
Old Jul 30, 2010 | 10:37 PM
65fstback's Avatar
65fstback
I have a 53 f100 with a 3 speed manual trans. I installed a new speedometer gear onto the cable and installed the cable into the trans. Ran the truck speedometer worked for a few seconds then stopped I removed the cable from the trans and found the gear had fallin into the trans. I had to remove the rear of the trans to retrieve the gear what a pain in the *** that was. Is there some way to hold this gear into the cable I just slid the gear onto the cable end is there a clip to hold it on or am I missing something.Thanks
Old Jul 31, 2010 | 01:13 AM
Julies Cool F1's Avatar
Julies Cool F1
Many of them are pressed on, but also many have a circular retaining clip as well. You know, the kind that looks like a washer with a slice cut out of it.
Old Jul 31, 2010 | 07:06 AM
sdetweil's Avatar
sdetweil
like Julie said, there should be a clip like shown here..
http://www.latemodelrestoration.com/...ear-Kit-Manual
Sam
Old Jul 31, 2010 | 07:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
8A17292 .. Retainer, Speedometer Driven Gear / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 800-546-7278.
NORTZ & VIRKLER FORD in Lowville NY has 14 = 315-376-6594.
AITKEN MOTOR CO. in Aitken MN has 46 = 218-927-2169.
I wouldn't be a bit surprised if the following is also missing, or if it's there, is hard as a rock. Either way, gear lube will leak past the cable.
1A17298 .. Oil Seal (O-Ring), Speedometer Cable / Obsolete
MILLER OBSOLETE PARTS has 3.
GREEN SALES CO. in Cincinnati OH has 23 = 800-543-4959.
Old Jul 31, 2010 | 10:51 AM
65fstback's Avatar
65fstback
There is no clip, Julie the gear you posted is a later model for mustangs. The gear I have has a long stem that slids into the cable end. It slids on and out easy wondering if cable end is worn and gear should snap on. Driving with no speedometer right now.Help
Old Jul 31, 2010 | 12:16 PM
Julies Cool F1
I think Sam posted that just as an example of what the clip looks like in general.
The part numbers and sources Bill posted are for the actual parts you need.
Point is there is a retaining clip that you are supposed to have, don't have, and will need to get in order for the gear to stay on.
Call one of the folks Bill pointed out to you to get one!
Old Jul 31, 2010 | 12:19 PM
sdetweil's Avatar
sdetweil
correct, I was just showing the kind of clip Julie was talking about in her response
Sam
Old Jul 31, 2010 | 06:31 PM
65fstback's Avatar
65fstback
This is the gear I used
Old Jul 31, 2010 | 06:32 PM
65fstback's Avatar
65fstback
This is the gear I used I don't think there is a clip for this type gear for 53 3 speed trans. Thanks
Old Jul 31, 2010 | 08:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Does it sit in the tranny and retained by a big nut like the one shown here? If so, there's no clip. You have to make sure the stem on the bottom gets into the hole in the trans or it will fall out. PS I"ve never seen a plastic gear for these, sure it's the right one?
Old Jul 31, 2010 | 10:29 PM
65fstback's Avatar
65fstback
No albuq f1 the gear goes into the end of the cable the push into hole in trans and bolt goes through tab on cable. This is a picture of cable I have on 53.
Old Aug 1, 2010 | 03:55 AM
NumberDummy
What that plastic gear is from/for, I haven't a clue...it sorta resembles the original steel gear all these trucks came with.
Old Aug 1, 2010 | 08:52 AM
65fstback's Avatar
65fstback
That is the stock gear for 1948-1960 regular 3 speed ford truck trans.
Old Aug 1, 2010 | 11:27 AM
Julies Cool F1
Really? Then it should work, Right?
In the cable replacement procedure it has a note telling you to ensure you have rotated the inside flexible cable and that it was fully "set" into the square hole on the gear. Did you do that? Are you sure your inside cable is long enough?
I have also seen these gears with the small shaft on the end lengthened some to act as a spacer.
The oil seal ring Bill mentioned goes into the groove on the end housing. And this cable is held in place with a retainig clip and bolt similar to the one pictured below.
Name:  Speedometer Cable Clip.jpg
Old Aug 1, 2010 | 12:59 PM
65fstback's Avatar
65fstback
Yes Julie that exactly how I installed it. I'll try it again tomorrow thought maybe I missed something but I guess not. Didn't want to install again till I checked to see if I did it right. A real pain to remove from rear of trans when it falls inside. Thank all for the help.Jim
