No AXLE code, any thoughts?
Old Jul 30, 2010 | 05:59 PM
60RatRod's Avatar
60RatRod
What do guys make of this no AXLE code, I suspect based on hitch and brake controller it was a special order with 4:10's or better. Call it wishfull thinking, but sure would like to know before I pull it.
Old Jul 30, 2010 | 06:06 PM
Duzitall's Avatar
Duzitall
No code on drivers door tag or either f/r axles? Come on...go look again.
Old Jul 30, 2010 | 06:14 PM
60RatRod's Avatar
60RatRod
could'nt actually get under the truck. 1 did'nt bring a jack, 2 rattlesnake made a home right under the pumpkin. its two wheel drive so no FR axle.
Old Jul 30, 2010 | 06:30 PM
jwhitetail's Avatar
jwhitetail
If it's single rear wheel it's more than likely 10.5 sterling, if it's dual rear wheels it's dana model 80.
Old Jul 30, 2010 | 06:33 PM
60RatRod's Avatar
60RatRod
single rear wheel for sure a 10.5, this is all I know so far.
Old Jul 30, 2010 | 06:37 PM
SpringerPop's Avatar
SpringerPop
He's looking for ratios, not type.
Pop
Old Jul 30, 2010 | 06:45 PM
Duzitall's Avatar
Duzitall
Sorry Dan, LOL, the pictures didn't show on my screen in the first post. I see the situation now. Gotta read the axle tag to know for sure unless you can turn the wheel and see the driveshaft. I'm gonna bet it's the 3.73 like 99% of the 7.3 SRW
Old Jul 30, 2010 | 06:47 PM
F350-6's Avatar
F350-6
You could always share with us what rpm's you're turning at say 60 or 70 mph and we could guess based on what we turn. If all the tags are gone, you can always move the truck away from the snakes, jack up the rear end and mark the bottom of the tire and bottom of the drive shaft. Then with the truck in neutral, count the revolutions since the rear end is just a ration. Over 4 turns per spin means a 4.10. Under means a 3.73.
I'm guessing you have a 3.73 like most other SRW trucks.
Old Jul 30, 2010 | 06:53 PM
60RatRod's Avatar
60RatRod
Yeah Chris, I am just hoping for 4:10 I just bought a 14K lbs fifth and would love to upgrade my 3:73 axle gears but I am lucky just to get access to this particular truck, i.e. someone in the family pulled some strings. If it has 4:10's I am welcome to take the axle, only I limeted to moving the PU.
Old Jul 30, 2010 | 07:00 PM
Duzitall's Avatar
Duzitall
I had the chance to order mine with 4.10 but made the wrong choice back in 2001. My truck has gotten by OK with the 3.73's but 4.10's would have been better with my 315 tires.
That is a BIG fiver you gotz there my friend. Best of luck. I hope you score.
Old Jul 30, 2010 | 07:23 PM
60RatRod's Avatar
60RatRod
Yeah I can get by fine too, but like you say would be nice. I am wondering if this truck was ordered w 4:10's and thats the reason for the axle code being left off. He had everything else set up for towing heavy. Yeah, sometimes I don't know what I'd do if I did'nt have family I can count on. With any luck maybee tommorow my cousin will be available to get me in and I can be prepared w/ something for the snake and the a 3 ton jack, slide under and have look at the axle tag. Although never could figure out how to read those dang axle tags.
rosesrfree4u
16
Sep 24, 2020 09:48 PM
gaselectjoe
2009 - 2014 F150
Mar 3, 2014 04:55 AM
Redgranite_Yooper
Jun 27, 2013 11:36 AM
1968 F100 Ranger
Oct 5, 2012 03:56 PM
bloydj
18
Feb 24, 2012 02:11 AM
