Sponsored by: Auxito
PO743 code
Old Jul 30, 2010 | 05:24 PM
ejames420's Avatar
ejames420
PO743 code
im getting a PO743 code today. my truck started sputtering and then died. when i restarted it th service engine light was on. i took it to a mechanic and they changed transmission fluid, pan gasket, filter and added trans x atf conditioner. it has 146000 miles on it. did they perform the right work?
Old Jul 30, 2010 | 10:40 PM
Bluegrass 7's Avatar
Bluegrass 7
we--ll, no because the code indicated has not been addressed and wont be addressed by a fluid/filter change.
The code 743 is the converter clutch electrical failure.
This is not related to fluid. It is electrical.
The computer operates the clutch, as such, registers the code because it monitors the electrical 'current' signiture.
If the computer does not see the correct action, it is logiced a failure and you see/feel the resulting operational failure.
A trans shop is you next stop to address the code and not guess about it.
Good luck.
tomeug69
Dec 10, 2015 08:48 PM
milwaukee2000
1997 - 2003 F150
Mar 21, 2015 06:12 PM
tanker2008
Illinois Chapter
Feb 7, 2010 01:14 PM
Jerry2197
1997 - 2003 F150
Jun 22, 2009 03:45 PM
