Need help with wiring!?!
Old Jul 28, 2010 | 09:45 PM
JT250's Avatar
JT250
2003 F250. I am not getting power to the center pin on my trailer wiring harness at the back of the truck. My fuse was blown so I replaced it. I swapped the relay and that didnt seem to make a difference either. I have tried to trace the wire (black w green stripe) from the cab to the connector. I also tested the wire that comes out of the fuse panel and dont seem to get power to it either. However, I dont know what wires are going into or coming out of the relay, so I dont know what to test there. I am getting power to one leg of the fuse panel when the fuse it pulled so I know it is hot there. I am not big on wiring. ANY HELP WOULD BE GREAT!!
