6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Please name that switch/sensor/plug, etc.
Old Jul 28, 2010 | 09:43 PM
dwilliamsceg's Avatar
dwilliamsceg
Below is a pic with 4 numbers (1-4). Will someone who knows the answer to what these items are, please describe them? This is not for fun, I don't know what these items are and wish to know more.
1- a mild yellowish box with plugs running into it
2 -a gray item that appears to be on the CAC tube
3 - two red toggle switches behind the air filter
4 - some sort of fitting going to what looks like a fuel line type connection.
P.S. These are off my early Job 1 (2008) with 53K miles. I love this truck
Old Jul 28, 2010 | 11:52 PM
pdombrowicki's Avatar
pdombrowicki
1. Vacum for 4wd
2.throttle body
3.ECM Engine Control Module
4. Ac line
Old Jul 29, 2010 | 09:07 AM
dwilliamsceg
Originally Posted by pdombrowicki
1. Vacum for 4wd
2.throttle body
4. Ac line
Thanks! A few more follow on...
1. I am surprised the 4wd is vacuum operated as opposed to solenoid/servo
2. Do I need to learn the throttle body like I do on a gasser?
3. What do the two red taggle switches on the ECM do?
Old Jul 30, 2010 | 10:18 PM
Tater Mash's Avatar
Tater Mash
I don't believe they are any kind of toggle switch. They are hold downs to "lock" the plugs on the wire harness to the ECM to keep them from vibrating loose. Not 100% sure on this but that is what they appear to be when I have looked at mine. Just my 2 cents.
Old Aug 1, 2010 | 01:59 PM
senix's Avatar
senix
Yes # 3 is the industry standard connection for those type of connections, they just pull back and release.
You have to be sure they go in the same way. Lots of pins for the harness.
No maint on the throttle body (#2).
