temperature guage
Old Jul 28, 2010 | 03:29 AM
Atwiss's Avatar
Atwiss
temperature guage
does anyone know where the temp guage hooks up on a 400, currently its screwed into the manifold but a local guy said it might go on the water pump on the top left where there is a little needle
Old Jul 28, 2010 | 03:42 AM
tinaheels's Avatar
tinaheels
its in the block by tha alt.
Old Jul 28, 2010 | 08:51 AM
fmc400's Avatar
fmc400
MSEE
It shouldn't go on the intake manifold, as a 400 has a dry manifold. It's in the block as tinaheels described.
If it's in the intake manifold, someone probably installed it in a vacuum fitting. Make sure you plug it back up.
Old Jul 28, 2010 | 10:06 AM
704 dentside man's Avatar
704 dentside man
The temp sending unit is right behind the alternator bracket. Kinda a pain to get to if you don't pull the alt and bracket out.
Old Jul 28, 2010 | 10:28 PM
Atwiss's Avatar
Atwiss
ok thanks yeah i guess it was on the block i coulda swore it was on the intake
oscajo
Jan 10, 2013 11:00 AM
Vinford
Dec 25, 2008 11:49 PM
1975Ford
25
Jan 25, 2007 08:19 AM
kylen77
Jul 2, 2005 09:20 AM
