Trany help
Old Feb 12, 2003 | 05:56 PM
99_Ranger_Red's Avatar
99_Ranger_Red
Angry Trany help
I am having 2 problems with my tranny. I have a 1999 ranger 3.0 v6 with E-OD trans and 4wd. It has 49k miles and is out of warranty (stupid me for not buying one.
The first problem is driving down the road the O/D off light starts flashing. This only happens intermitently. If I shut the engine off and restart it, it goes away, only to return a short time later under the same circumstances.
Problem 2, about 60% of the time when 2nd gear engages there is a moderate to sometimes harsh jolt as 2nd gear is engaged. The other 40% of the time it shifts normally. When I encounter the problem it will only shift when I release the gas pedal a little. Other wise it will not shift and tap the rev limiter.
I have changed the transmission fluid and installed a new filter. This has helped slightly decrease the number of 2nd gear engagement problems but has not helped any with the O/D off light.
I would appreciate any help with this. Thank you in advance for any help or suggestions.
Old Feb 12, 2003 | 07:44 PM
Ken00's Avatar
Ken00
Trany help
Welcome to Ford Truck Enthusiast!
The OD light is indicating an electrical/computer problem, the most common cause is the VSS. If you get the codes pulled you can find out what the possible causes are, I don't think you have a serious tranny problem.
Old Feb 13, 2003 | 06:53 PM
99_Ranger_Red
Trany help
what is the VSS?
Old Feb 13, 2003 | 08:03 PM
Ken00's Avatar
Ken00
Trany help
Sorry about that, it's the vehicle speed sensor.
Old Feb 13, 2003 | 08:51 PM
01RangerSC's Avatar
01RangerSC
Trany help
Valve body gasket is probably blown out. Take it to the dealer and have it diag'ed. Have them install the parts from ford tsb 02-13-08 also. Left unfixed, serious trans damage WILL occur.
