Newbie Question - Whats my engine?
Old Jul 27, 2010 | 05:51 PM
scseth's Avatar
scseth
Bought a '56 Ford F100 from an estate sale. Engine runs, low body rust. I was told the engine was a V8 292 and was stock however the VIN indicates it was sold with a V6. The '56 V8 was a 272. The air filter housing has a 292 sticker so its possible its a 292 from '59 but some of the carburetor gaskets didnt match. Are there any model numbers printed on the block or somewhere I can look to pin it down.
Here's a pic in case anyone can ID it.
<img src="http://img22.imageshack.us/img22/334/009cky.jpg" alt="Image Hosted by ImageShack.us"/>
Thanks
Old Jul 27, 2010 | 06:12 PM
52 Merc's Avatar
52 Merc
For starters, Welcome to the Forum!
Your engine is from the Y-block family, which includes the 272, 292, and 312 as the more popular sizes. I'm not sure if there is any way to absolutely distinguish the differences externally. But if there is a way, someone here will know.
Regarding your VIN question. First, Ford didn't have a V6 engine back in the 50's. So if it was a 6 cylinder in there originally, it would have been an inline 6, not a V6, fyi. The next thing is, where did you look for your vin number? The title? Stamped frame number? Data tag? Did you check to make sure all of your numbers are matching? Tags and parts they're attached to are easily and frequently swapped, so you really want to check for the stamping on the frame, typically found on the top of the right side (passenger) frame rail, under the hood between the cab mount and core support crossmember. They can be hard to see as they're not always stamped real hard. Take a look and let us know what you find.
Old Jul 27, 2010 | 07:13 PM
scseth's Avatar
scseth
Thanks 52 Merc for the quick response.
I was using the serial # printed on the tag on the side of the cab as the VIN. And actually, I just realized I was reading it incorrectly. The serial started with F10V6 which I guessed wrong was an F100 V6, but as you mentioned there was no V6 only inline. According to 56 F100 | 1956 Ford | Truck | F100 | Information | Parts
looks like
V = O.H.V. 8 Cylinder-2V Carb (L/D)-272 cid
and the
6 = 1956
So perhaps it is stock 272 or was upgraded to a 292. If love to hear if anyone can tell the difference
Thanks
Old Jul 27, 2010 | 07:37 PM
56panelford's Avatar
56panelford
Welcome aboard, I'm not able to pin point to the exact displacement you have but the 56 pickup I have had a 272 in it. Don't be shy and show some more pics of your truck sounds like it's in pretty good conditon.
Old Jul 27, 2010 | 08:07 PM
scseth's Avatar
scseth
Thanks 56panelford
A few more pics for you to compare
<img src="http://img823.imageshack.us/img823/8799/img4541r.jpg" alt="Image Hosted by ImageShack.us"/>
<img src="http://img189.imageshack.us/img189/9407/img4540g.jpg" alt="Image Hosted by ImageShack.us"/>
And a couple for fun
<img src="http://img186.imageshack.us/img186/9232/img4542.jpg" alt="Image Hosted by ImageShack.us"/>
<img src='http://a.imageshack.us/img840/4364/img4538b.jpg' border='0'/>
Old Jul 27, 2010 | 09:41 PM
grumpy46's Avatar
grumpy46
good looking truck
Old Jul 28, 2010 | 12:28 AM
55 f350's Avatar
55 f350
good looking truck ! welcome to the nut house . and wander over to john mummerts yblock site . he's got tech articles that will help you distinguish what you have . in the case of mine after i removed all the parts stu needed back i took the flywheel off and looked at the crank and the shape of it told me what it was , thanks to the aforementioned site .
Old Jul 28, 2010 | 03:54 AM
big job's Avatar
big job
engine ?
I see no filter/draft tube, and i see the late carbruator. Check to see if
it has a factory pvc valve should be around the coil area. I have a
64 F350 a 272 and it has that carb no draft tube and it has a pvc.
sam
Old Jul 28, 2010 | 07:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1956 F100/350: The only available V8 was the 272 2V. The 292 was not available until 1957.
First use of the PCV (Pollution Control [smog] Valve) system = 1961. Mandatory in CA initially, by 1963 all cars/trucks had it.
Y blocks w/a PCV use a cannister with a nipple on it in place of the road draft tube.
292 2V: A short rubber hose clamps to the nipple then clamps to a steel tube that winds it way along the right (passenger) side valve cover. Another short rubber hose connects the tube to the valve.
The valve threads into a brass fitting that threads into the intake manifold...just in front of the carb.
Since I see none of this jazz, the PCV has either been removed and the nipple capped off, or the engine never had it.
