Passenger battery heatshield
Jul 27, 2010 | 04:57 PM
Just checked with the local dealers for the battery blanket replacement and one dealer wants $47.98 + tx. and the other $39.99 + tx.
Man are they pround of that 2 bit blanket. Think I will get some insulating material and make one. Wouldn't be so bad if they lasted.
Jul 27, 2010 | 05:08 PM
Mine has nothing on the passenger side battery. Only the drivers side has a cover. What is this thing of which you speak?
Jul 27, 2010 | 05:18 PM
mine only has a pass side and acid sheild on the drivers
maybe a cold weahther thing? but both my Chevys have them
Jul 27, 2010 | 05:22 PM
I think you should save your time and materials and not worry about it Mike. Mine went in the trash about 4 years ago. I never could figure out if it was supposed to protect the battery from heat or cold or how it was supposed to do either--LOL.
Jul 27, 2010 | 05:36 PM
Jul 27, 2010 | 05:40 PM
It's supposed to protect the battery from the heat of the metal turbo tube that is about 1 inch from the corner of the battery.
Jul 27, 2010 | 06:12 PM
I've got one on the passenger side.If someone wants to give me $47+ dollars you can have mine!
Jul 27, 2010 | 06:44 PM
Maybe someone thought it wasn't already crowded enough under the hood.
Jul 27, 2010 | 08:15 PM
So is it needed?
So is this blanket really needed? Also I installed a coolant filter and a coolant line touches the turbo pipe. Is this something I such be concerned about? Should I try and tie it back so it doesn't touch the pipe?
Jul 27, 2010 | 10:08 PM
I wouldn't like the chafe issue alone so I would cut a section of the next couple sized hose up and slit it longwise as a protection sleeve
Jul 27, 2010 | 11:37 PM
Thanks Zmann! Good idea. Would you have any insight on another post i have about if running off road diesel in my 6.0L would hurt the engine?
Jul 28, 2010 | 09:18 AM
Quote:
Originally Posted by
jayhawk714
It would really hurt if you got caught. Huge fines in the thosands here.
Jul 28, 2010 | 10:18 AM
yup ! They do roadside dip test here in AZ and the fines are huge for running red died diesel AKA offroad
Jul 28, 2010 | 12:51 PM
here all you need is farm plates and you can run it in your truck
Jul 28, 2010 | 12:56 PM
I heard you have easy emissions also?
