Need an acronym thread
Old Jul 27, 2010 | 03:22 PM
ruaduck's Avatar
ruaduck
I think for us nubs, newbs and newbies, we need an acronym guide. I read through alot of these posts and it confuses the hell out me because i go WTF is FICM? If anyone would be willing to help this out i would love it. It just would help me understand what you professional guys are talking about.
Thanks
Cris
Old Jul 27, 2010 | 03:34 PM
Cowboy65's Avatar
Cowboy65
Follows are a couple of links that I bookmarked from a recent thread that might help out.
DTS Glossary of Terms
Glossary of Automotive Acronyms .: Articles
Old Jul 27, 2010 | 05:11 PM
bpounds's Avatar
bpounds
We could do that, but then everyone would know our business. I guess we could have a secret handshake or something.
Old Jul 27, 2010 | 06:57 PM
cheezit's Avatar
cheezit
bill I dont know why you sig line says green handle but.... the handles should really be yellow. after all you dont put diesel in a green or red gas can. it goes into a yellow fuel can.
I really dont know who started the "green handle" thing
so far as acronims goes I had a fairly complete list a few years back I may still have it. I wanna say it went back about 15 years and was something like 47 pages.
If I ever find it again Ill send it to mark to file it.
2003 EXCURSION's Avatar
2003 EXCURSION
Thanks
Cris
I agree, particularly for those who are new to this site. When I was first on here, it was hard to get through a thread and understand half of what was being said. Those of us who have been here for a while become unaware of the numerous acronyms used here, with the presumption that everyone knows what we are talking about. It would be a nice addition to this or any site. Mike
Old Jul 27, 2010 | 07:04 PM
william_04_x's Avatar
william_04_x
Here's a list of acronyms i've been posting on a few sites over the years.
ABS A<acronym title="Anti-Lock Braking System"></acronym>ntilock Braking System
<acronym title="Air Conditioning"></acronym><acronym>AC A</acronym>ir Conditioning
<acronym title="Air Conditioner Clutch"></acronym><acronym>ACC</acronym> Accessory Position of ignition key
ACC <acronym title="Air Conditioner Clutch"></acronym><acronym>A</acronym>ir Conditioning Clutch
<acronym title="Auxiliary Idle Controller"></acronym><acronym>AIC A</acronym>uxiliary Idle Control (see APCM<acronym title="Fords name for AIC"></acronym>)
<acronym title="Fords name for AIC"></acronym><acronym>APCM A</acronym>uxiliary Powertrain Control Module(FORD's name for <acronym title="Auxiliary Idle Controller">AIC</acronym>)
AP Accelerator Position
API - American Petroleum Institute
APS Accelerator Position Sensor
<acronym title="Automatic Transmission Fluid">ATF</acronym> Automatic Transmission Fluid
<acronym title="Barometric Pressure Sensor">BARO</acronym> Barometric Pressure Sensor
BOO Brake On/Off
<acronym title="Charge Air Cooler">CAC</acronym> Cold Air Charge/Charge Air Cooler
CAN Controller Area Network<acronym title="Crew Cab, Credit Card">
CC
</acronym> Crew Cab (4 door)
CDR Crankcase Depression Regulator
<acronym title="Check Engine Light">CEL</acronym> Check Engine Light
CLV - Calculated Load Valve
<acronym title="Camshaft Position Sensor">CPS</acronym> Cam Positioning Sensor
<acronym title="Crank Case Ventilation">CCV</acronym> Crank Case Ventilation
DI Direct Injection
DLC Data Link Connector(<acronym title="On Board Diagnostics">OBD</acronym> connection)
DORA Dealer Order Receipt Acknowledgment
DPF Diesel Particulate Filter
<acronym title="Daytime Running Lights">DRL</acronym> Daytime Running Lights
DRW Dual Rear Wheels, dually, Dooley
<acronym title="Diagnostic Trouble Code">DTC</acronym> Diagnostic Trouble Code(usually P-xxx/xxxx)
DVOM/DVM Digital Volt-Ohm Meter/Digital Volt Meter
<acronym title="Pre 99 Automatic 4 speed transmission">E4OD</acronym> auto tranny on pre-'99 Ford heavy pickups
EB Exhaust Brake
<acronym title="Exhaust Back Pressure">EBP</acronym> Exhaust Back Pressure
EBPR/EPR Exhaust Back Pressure regulator
<acronym title="Exhuast Back Pressure Sensor">EBPS</acronym> exhaust back pressure sensor
EBV/EBPV Exhaust Backpressure Valve
ECM - Engine Control Module
ECT Engine Coolant Temperature
EEC(M) Electronic Engine Control (Module)
<acronym title="Exhaust Gas Recirculation">EGR</acronym> Exhaust Gas Recirculation
<acronym title="Exhaust Gas Temperature">EGT</acronym> Exhaust Gas Temperature
<acronym title="Engine Oil Temp">EOT</acronym> Engine Oil Temperature
<acronym title="Electronic Shift On the Fly">ESOF</acronym> Electronic Shift On-The Fly
ESP Extended Service Plan
FAQs Frequently Asked Questions
<acronym title="Fuel Injector Control Module">FICM</acronym> Fuel Injector Control Module
FIPW Fuel Injection Pulse Width
<acronym title="Gross Axle Weight Rating (Max Rating of each Axle)">GAWR</acronym> Gross Axle Weight Rating
<acronym title="Gross Combined Weight Rating (Max rating of vehicle plus trailer)">GCWR</acronym> Gross Combined Weight Rating
GEM Generic Electronic Module
GP Glow Plug
GPC Glow Plug Controller
GPR Glow Plug Relay
<acronym title="Gross Vehicle Weight Rating (Max recommended weight of vehicle plus payload/cargo)">GVWR</acronym> Gross Vehicle Weight Rating
<acronym title="Gross Vehicle Weight">GVW</acronym> Gross Vehicle Weight
GW Gross Weight
<acronym title="Hydraulic-Electric Unit Injection">HEUI</acronym> Hydraulic-actuated Electronically-controlled Unit Injector
HFCM Horizontal Fuel Conditioning Module
HIC Hybrid Instrument Cluster
<acronym title="High Pressure Oil Pump">HPOP</acronym> High Pressure Oil Pump
<acronym title="High Pressure Crossover">HPX</acronym> or H/X - High Pressure oil crossover mod that connects the two HP oil rails together
<acronym title="Intake Air Temp">IAT</acronym> Intake Air Temperature
I/C Intercooler
<acronym title="Injection Control Pressure">ICP</acronym> Injection Control Pressure
ICPR Injection Control Pressure Regulator
<acronym title="Indirect Injection">IDI</acronym> In Direct Injection
<acronym title="Injector Driver Module">IDM</acronym> Injector Driver Module
<acronym title="Injection Pressure Regulator">IPR</acronym> Injection Pressure Regulator
<acronym title="Idle Validation Switch">IVS</acronym> Idle Validation Switch
<acronym title="Key ON Engine OFF">KOEO</acronym> Key On Engine Off
<acronym title="Key ON Engine RUNNING">KOER</acronym> Key On Engine Running
<acronym title="Long Bed">LB</acronym> Long Bed
LED Light emitting diode
<acronym title="Low Pressure Oil Pump">LPOP</acronym> Low Pressure Oil Pump
LS Limited Slip
<acronym title="Limited Slip Differential">LSD</acronym> Low Sulpher Diesel
<acronym title="Long Wheel Base">LWB</acronym> Long Wheel Base
<acronym title="Mass Airflow Sensor">MAF</acronym> Mass Air Flow Sensor
<acronym title="Manifold Absolute Pressure - MAP Sensor">MAP</acronym> Manifold Absolute Pressure Sensor
MIL Malfunction Indicator Lamp
NC Normally closed(referring to a switch)
NGS New Generation Star (Ford vehicle diagnostic scan tool)
NO Normally open(referring to a switch)
NOx Oxides of Nitrogen
OASIS On-line Automotive Service Information System
<acronym title="On Board Diagnostics">OBD</acronym> On Board Diagnostics
<acronym title="Old Body Style">OBS</acronym> Old Body Style
<acronym title="Over Drive">OD</acronym> Over Drive
OEM Original Equipment Manufacturer
OTC Overhead Trip Computer
<acronym title="Passive Anti Theft System">PATS</acronym> Passive Anti-Theft System
PBA Parking Brake Applied
PCED Powertrain Control/Emissions Diagnosis service manuel
<acronym title="Powertrain Control Module">PCM</acronym> Powertrain Control Module
PCV Positive Crankcase Ventilation
PDL Power Door Locks
PM Power mirors
<acronym title="Powdered Medal Rod">PMR</acronym> Powdered Metal Rod
PPM Parts per million(associated with emissions)
PS Power Steering / Power Stroke
<acronym title="Power Stroke Diesel">PSD</acronym> Power Stroke Diesel
PTO Power Take Off
PTTTM Power Telescoping Trailer Tow Mirrors
<acronym title="Pulse Width">PW</acronym> Power Windows
PW-Pulse Width
<acronym title="Pulse Width Modulation">PWM</acronym> Pulse Width Modulation
RABS Rear Anti Brake System
<acronym title="Regular Cab">RC</acronym> Regular Cab
<acronym title="Short Bed">SB</acronym> Short Bed
<acronym title="Super Cab">SC</acronym> Super Cab (extended cab)
SCA Supplimental Coolant Additive
<acronym title="Super Duty">SD</acronym> Super Duty
SEIC Stationary Elevated Idle Control
SRS Supplemental Restraint System (air bags)
SRW Single Rear Wheel
<acronym title="Short Wheel Base">SWB</acronym> Short Wheel Base
<acronym title="Torque Converter">TC</acronym> Torque Converter or Transfer Case
<acronym title="Torque Converter Clutch">TCC</acronym> Torque Converter Clutch
TCIL Transmission Control Indicator Light (<acronym title="Over Drive">OD</acronym> off)
TCM Transmission Control Module
TCS Transmission Control Switch (<acronym title="Over Drive">OD</acronym> off Button)
TFT Transmission Fluid Temperature
T/H Tow Haul
<acronym title="Throttle Position Sensor">TPS</acronym> Throttle Position Sensor
<acronym title="Technical Service Bulletin">TSB</acronym> Technical Service Bulletin
TTB Twin Traction Beam
TTM Turbo Temp Monitor
TTM Trailer Towing Mirrors
ULSD Ultra Low Sulpher Diesel
UVCH Under Valve Cover Harness
<acronym title="Volts A/C - Volts Alternating Current">VAC</acronym> Volts Alternating Current
VDC Volts Direct Current
VECI Vehicle Emissions Control Information
VIN Vehicle Identification Number
VGT Variable geometry turbo
VREF Voltage Reference
<acronym title="Vehicle Speed Sensor">VSS</acronym> Vehicle Speed Sensor
VVGT Variable vane geometry turbo
<acronym title="Wide Open Throttle">WOT</acronym> Wide Open Throttle
Old Jul 27, 2010 | 07:06 PM
bpounds's Avatar
bpounds
The site has this acronym thread, but it's in a gasser forum and doesn't have a lot of diesel stuff. But still a lot of it does apply.
https://www.ford-trucks.com/forums/1...finitions.html
We could just start one, and everyone can contribute. Now that we can freely edit our posts it would be very easy to do.
Around the west they mostly seem to be green handles. I have seen some yellow ones. So I know it is not universal. You knew what I meant though, right?
Edit: Oops, beat by thaaaat much. Thanks Will.
Motorcityiron
1997 - 2003 F150
Nov 11, 2021 10:43 AM
Midwest Dually
1983 - 2012 Ranger & B-Series
36
Feb 14, 2019 06:02 PM
Bird-Dog 250
22
May 15, 2018 01:27 PM
Motorcityiron
General Automotive Discussion
Apr 24, 2015 12:27 PM
Awitte58
May 25, 2011 06:49 PM
