A few bugs...
Old Jul 27, 2010 | 03:21 PM
Wicked Endings's Avatar
Wicked Endings
A few bugs...
Hey all!
It's been a while since my last post. I've been gone working on a log home in Tennessee.
Anyone ever heard of Maynardville, TN before?
Yeah... I never knew it existed either.
Anyways..
A few bugs with the truck..
- - My truck won't start at the key. I have to jump it at the solenoid.
- - My front right brake keeps locking up. My suggestion is changing the brake caliper.
- - I have brake lights, turn signals, but when I turn my lights on at night, my back lights don't come on.
So, minor problems. Well, the last one is pretty important. So is the second, but I can fix that.
Can someone give me advice?
Old Jul 27, 2010 | 06:51 PM
Barkin 40s's Avatar
Barkin 40s
probably a fuse for both the lights and ignition
Old Jul 27, 2010 | 08:36 PM
Crankylove's Avatar
Crankylove
The issue with the lights makes me think its grounding out somewhere.
Brakes........I too would replace the caliper.....although I would pull it first to see if there was anything visually wrong first.
Old Jul 27, 2010 | 09:59 PM
ctubutis's Avatar
ctubutis
Try adjusting the column-mounted ignition switch - when you turn the key to START, do
you NOT hear the solenoid click? Probably not is my guess (although you normally wouldn't
hear it as the starter motor noise overpowers that). When in START, the radio & other
accessories should shut off.
Tail lights not working - check the bulbs. All the running lights on all 4 corners use the same
circuit, a single, brown wire. This lighting is independent of stop & turn lights. As already
mentioned, grounds are a possibility, too.
Probably need a new or rebuilt caliper, remove it and see if you can squeeze the piston
back into the cylinder using ChannelLocks or other, large pliers.
Ever heard of Toad Suck, AR?
