egr removal?
Old Feb 12, 2003 | 02:46 PM
rustynuts's Avatar
rustynuts
egr removal?
can i remove the egr valve and plate? will this affect emmisions and or performance?stock 79 400 with 2 bbl.
Old Feb 12, 2003 | 03:09 PM
macguyver's Avatar
macguyver
egr removal?
If you remove the spacer the linkage might not clear the intake. And yes, it will affect emissions and performance. NOx emissions will increase due to the higher combustion temperatures and pinging will increase without adjustments to the timing and fuel curves.
Can it be done? In a word, yes. Would I recommend it? No. Others might though. It would depend on how you were going to use it.
Just my $.02
Greg
Old Feb 12, 2003 | 11:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
egr removal?
Ditto with Macguyver!
Old Feb 13, 2003 | 12:03 AM
TMI's Avatar
TMI
egr removal?
I have had 2 different customers that when we did a valve job they eliminated the egr valve and they stuck, and bent a valve. The egr valve helps bring the combustion temp down, when temps get high the valves seem to "swell" alittle and get "lazy" in the guide movment. Then the piston comes and gives thema little tag!!
