New Wiring Harness
New Wiring Harness
Had a fire in my dash from a bad aftermarket remote start. Replaced the dash from an expidition which fit perfect......problem is I used the wiring harness from the expidition also.....everything went bfine on the install till I got over on the driver side....the wiring going under the seat didnt match up.......any help would be appreciated? Should I get wiring harness from a f150 like mind? Surely you can match up the wiring....from an expition wiring vs an f150?
