Intermittant problem starting. What to check?
It has only done this two or three times and the weather was cold each time. Each time after cranking it for a minute or two it starts up and runs smoothly. If I turn it back off, it starts fine the next time.
I have added dry-gas each time that it happened since I though it could be moisture but I'm not convinced since it has recurred.
What should I start checking? Also, if this turns out to be something I can't identify, will the dealer be able to check the computer and see what the trouble was even though it has been started and driven since the issue?
