89 4.9L bucking
Old Jul 25, 2010 | 09:27 PM
yak3d's Avatar
yak3d
89 4.9L bucking
I have an 89 f150 4.9L w/5spd. 92,000. The engine is bucking/missing intermittently when under very light load/only maintaining constant speed, doesent do it on decell or under loaded throttle. I have litteraly replaced every ignition componant on the truck short of the ecu. I have also replaced the majority of the fuel system parts. injectors, filter, high pressure pump, I use lucas fuel treatment religiously. any new ideas would really help, im fresh out!
Old Jul 25, 2010 | 10:52 PM
DreadyDiggs's Avatar
DreadyDiggs
Fuel pressure regulator possibly? If I understand you correctly the engine won't buck if you open the throttle with the truck parked?
You can still hook a fuel pressure gauge up to your truck and while it's parked open the throttle and watch the fuel pressure. If it drops in a way that's abnormal it'll cause bucking when you've actually got a load on the engine besides itself.
Does the truck do anything else besides this? Any codes?
Old Jul 26, 2010 | 09:44 PM
yak3d's Avatar
yak3d
Figured it out!! Too much egr.
Follow this link to learn more
https://www.ford-trucks.com/forums/9...-throttle.html
