Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cooling System Guides
- How to Replace Radiator Fan
Step by step instructions for do-it-yourself repairs
Radiator Fan CFM airflow?
The Durango came factory with a mechanical fan and an electric fan that kicked on during heavy use or stop and go traffic. I set them up to work together and never had an issue. It enabled me to increase the HP by a few ponies while keeping it cooler during towing. I also cut the factory shroud out since it was no longer needed.
You don't need a shroud made. Many many many people of done these swaps and used the stock E fan shroud. It works just fine.
E fan swap should cost right at $100
http://www.fordmuscle.com/archives/2...cfan/index.php
ive been told the sweet spot for the e-fans is the blades about 1 inch off the rad using a home made shroud to mount it and channel the airflow through the entire rad......
this wouldnt be a problem on open road....anything over 35 and any fan is about useless anyway.....but in heavy stop and go it makes all the difference in the world
#28
well any fans cfm is going to drop when u throw something infront of it and try to make it pull air threw it
ur going to get more airflow threw a single core rad. than u with with a 3 core and the same goes if u have a/c or not
u may be able to breath great threw a water hose then fill that same water hose with stir straws... ur not going to be breathing the same.... if what im getting at makes sense to u
so as far as fake cfm ratings idk i doubt it... they are probably measuring that with nothing infront of the fan
and the high and low fan settings... its not needed... im running my dual fan setup off a 95 firebird that had a 5.7 and it keeps my 5.0 nice and cool even with the single core rad...
i used the preset thermostat that is at 185*F and i also wired it to come on with the a/c
if one of the fan motors burn up i can go to the parts store and get a new one for $25 unplug and unbolt the old one throw the new one on and plug it in then its good to go
yes i got the wiring harness with my fans... shroud too
#29
I used the word fake intentionally, not that they were tested against 'nothing', which is advertised as '0' s.p or t.s.p. What isn't widely known is their is no standardized testing process's for fans and a lot of the advertised cfm's you see in ads are made up. Hitokori you obviously have an idea of the fundamentals of airflow, but unfortunately, most don't and think a 3000 cfm fan will move that. What I found was when I contacted some manufacturers to ask about their ratings, they said they would not be affected when against a radiator, which you obviously know is b.s. They were the first fans I tested and at 0 s.p. they weren't within a 1000 cfm of what they advertised. Once I started contacting people and letting them know what I did, had some manufacturers level with me on some of what's going on in the industry and it's such a scam, but 'everyone is doing it'. I did airflow testing on my expedition at the time this all started, needed 2k through the radiator for cooling based on measurements taken with calibrated equipment...(but keep in mind a fan advertised at 2k won't move that).
I was working to develop a standard for an offshoot of my business, but figured out no one would pay for it because all it would do is expose the crap that's out there.
#30
lol some people are greedy i guess.... all about making money and sticking it to the customers
:P but as far as paying these $300-$500 e-fan setups that are out there... **** that....
there was a bunch of V8's put in cars... some have radiators almost the same with as these trucks... the one i have is like 1/2" smaller than the radiator and if i would have centered it it would have been a 1/4" on the left and right... up and down it was the same
the way i figured it... if i have to go buy 2 new motors for the fans im still coming out cheaper than anything u can go buy new lol and it work just as good if not better
