i have a 2001 7.3 and was stranded when i went to crank my truck and it fired up just fine and then no matter if its in park reverse nuetral or drive it will not rev up its like im not hitting the gas pedal at all
i have asked the local deisil mechanic and he said he had no clue what it could be ...now i have recently switched to bio diesil but havent had a problem with losing power and just changed the fuel filter
and mix it half and half
Hey - this can be a variety of things. First and foremost is a defective pedal assembly that was recently recalled by Ford. I had the same problem a few years back - same deal.
if it is the TPS it is a simple relatively cheap fix. The shop i took mine to wanted 150$ for the part and 70$ for labor. i got the part from partsguyed for about 80$ shipped and put it in myself in about 5 minutes.
