WHATS THE PROBLEM
Old Jul 25, 2010 | 07:24 AM
johnsjsj's Avatar
johnsjsj
WHATS THE PROBLEM
<HR align=center color=#d1d1e1 SIZE=1 width="100%" noShade>
<!-- / icon and title --><!-- message -->A FRIEND HAS A 2003 <NOBR style="FONT-FAMILY: inherit; COLOR: darkblue; FONT-WEIGHT: bold" id=itxt_nobr_0_0>F250<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"> <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape style="WIDTH: 7.5pt; HEIGHT: 7.5pt" id=_x0000_i1026 alt="" target="_blank" type="#_x0000_t75" href="https://www.ford-trucks.com/forums/976935-possible-cps-problem.html##" o:button="t"><v:imagedata o:href="http://images.intellitxt.com/ast/adTypes/mag-glass_10x10.gif" src="file:///C:\Users\Johnson\AppData\Local\Temp\msohtml1\01\cl ip_image001.gif"></v:imagedata></v:shape></NOBR>SUPERDUTY WITH A 6.0. IT IS ACTING SIMILAR TO A BAD CPS ON A 7.3; IT WILL BE RUNNING DOWN THE ROAD FINE AND THEN ACTS LIKE YOU SHUT THE KEY OFF. HE SAYS HE PULLS TO THE SIDE OF THE ROAD AND IT WILL START RIGHT UP AND DOWN THE ROAD HE GOES AGAIN FOR AWHILE AND THEN IT HAPPENS AGAIN.THERE ARE NO OTHER PROBLEMS OR SYMPTOMS OFF ANYTHING. I AM NOT FIMILIAR WITH THE 6.0 SO I AM LOOKING FOR SOME HELP SO I CAN HELP HIM OUT. DO THEY HAVE A SIMILAR CPS PROBLEM LIKE THE 7.3 OR IS IT SOMETHING ELSE?
THANKS <o></o>
<!-- / message --><!-- sig -->
Old Jul 25, 2010 | 07:36 AM
npccpartsman's Avatar
npccpartsman
It needs to be code scanned. On a 6.0 a CPS is virtually bulletproof although with the engine "stalling" it may throw a CPS code and the CPS be fine. It could be a harness chaff problem--it was fairly common on early 6.0's--and it may not throw a code.
Old Jul 25, 2010 | 09:57 AM
f350fixaliter's Avatar
f350fixaliter
it could possibly be the icp sensor going out too, i know my truck was doing that when the icp sensor started to go out..
