Power window motor
Old Feb 12, 2003 | 02:47 AM
1993F150XL's Avatar
1993F150XL
Power window motor
I have an 85 F-150 on which the driver's side power window motor has died. I also have an 86 Town Car (junk parts car). I was wondering if the motors were the same. I went to autozone.com & the part # matched with the rear DS motor of the Lincoln, but I don't know how much I trust them. Does anyone know if this will work or can anyone tell me where I might find Ford part #s? I would hate to go to the trouble of removing this to find out it won't work. Thanks for any info.
Old Feb 12, 2003 | 07:32 AM
steve83's Avatar
steve83
Power window motor
It'll work.
Old Feb 12, 2003 | 08:07 PM
1993F150XL's Avatar
1993F150XL
Power window motor
Thanks, Steve. I thought it would, but I wanted to be sure.
Old Feb 13, 2003 | 09:26 PM
73doc's Avatar
73doc
Power window motor
according to whats wrong with the motor it can probally be repaired for less than 20 bucks and a few hours of your time. it may simply need the bushings or as they are called a peanut kit replace and be good as new
Old Feb 14, 2003 | 03:47 AM
1993F150XL's Avatar
1993F150XL
Power window motor
I will try the Lincoln motor being as I already have it (I may save $20), but if I find out it is bad, I will try to rebuild mine. Thanks for the input.
Old Feb 15, 2003 | 04:12 PM
nzabka's Avatar
nzabka
Power window motor
Can a guy get a rebuild (peanut) kit at your local NAPA or is this something only available thru a dealer?
Old Feb 15, 2003 | 09:45 PM
73doc's Avatar
73doc
Power window motor
I know the dealer i work for sells them to do in shop repairs or to customers but i guess napa should sell them. i really havent purchase them any where else
Old Aug 9, 2003 | 11:17 PM
tllawler's Avatar
tllawler
Smile Power window motor
I work on power windows for a living and I do know that the back door window motor out of the towncar will work. The front doors will not. They used a complety different motor for the minivent window regulators.
-Edited by Admin-
https://www.ford-trucks.com/guidelines.html
Old Aug 16, 2003 | 12:02 PM
sarblack's Avatar
sarblack
Question Power window motor
what would make just the left power window on a 2000 ranger not work while the right one does work? It is not a fuse or a relay because I have checked them. can anyone give me some help down here in Tennessee? thanks
Old Aug 16, 2003 | 08:24 PM
hermangarza's Avatar
hermangarza
Power window motor
does ford use the same window motor on all 80-96 trucks?
Old Aug 16, 2003 | 10:41 PM
tllawler's Avatar
tllawler
Power window motor
It could be the switch or the motor.
Old Aug 16, 2003 | 10:44 PM
tllawler's Avatar
tllawler
Power window motor
[QUOTE]Originally posted by hermangarza
does ford use the same window motor on all 80-96 trucks? [/QUOTE
They changed to a flat style motor in 93 but yes they do bolt up and work the same in all full size Fords from 80 to 96
Old Aug 16, 2003 | 10:48 PM
tllawler's Avatar
tllawler
Power window motor
The back door motors will work, the front door motors will not.
Old Aug 17, 2003 | 12:52 AM
hermangarza
Power window motor
i have one door with a electric window and one standard. both of them are 87-91. so if the towncars back doors motor work on the 80-86 then they will work on 87-91, maybe the steering wheel might bolt on also.
Old Aug 17, 2003 | 12:50 PM
tllawler's Avatar
tllawler
Power window motor
Yes, the window motors will work and I do think the steering wheel will also but I'm not sure. All you can do is try, I think the column is the same.
