78 F250 problem
Old Jul 24, 2010 | 04:16 PM
blacklabel21's Avatar
blacklabel21
78 F250 problem
Hey i am new to these forums.I have a 1978 f250 5.8m 4 speed 4x4. Well today i figure i would install the light that came with the sunpro temperature tack.Had it all hook up and it worked fine.I was about to leave and tryied to start it up but it didnt start.And i knew it was acting weaird becuase it makes a noise when its about to start and the radio didnt even want to turn on at all.I would check the fuses but i dont know what any of them do.I dont think its the starter.I wounder if i did damage by not connecting the bare wire to the battery.I could use some help on this one thanks.
Old Jul 25, 2010 | 06:10 PM
4x4 Bart's Avatar
4x4 Bart
Unhook any wires you attached and see if this corrects your problem. Next pull each fuse, one at a time, and look to see if the wire inside is burned in two and replace as necessary.
Old Jul 25, 2010 | 06:17 PM
NBC-Steve's Avatar
NBC-Steve
Clean your battery terminals. If still no success jump start your truck.
Old Jul 25, 2010 | 06:37 PM
blacklabel21
It was my postive battery terminal.I thought it was fuses to but it wasnt.I will post some pictures of my truck.
