92 Flareside electrical Headache!!
Old Jul 24, 2010 | 03:12 PM
SilverFlare92's Avatar
SilverFlare92
92 Flareside ext cab 351 auto. So I have a problem with electrical. I think it is a ground problem but all the grounds that I have found look good. I have no spark no fuel pumps, and the computer wont even run the obd test. I cant read volt across a fuse unless I ground it somewhere other than the fuse. If i put my positive lead on a fuse and negative lead on a body ground then i get voltage. This problem is in the power distribution box under the hood and also the inside fuse box. I was just driving and the truck quit. I replaced the module, the coil, and because I broke it the distributor, thinking it was a spark issue. It will turn over all day but wont start. I checked and cleaned every ground I could find. Please if anyone has any ideas please help. I am at my wits end with this thing. thanks in advance.
Old Jul 24, 2010 | 03:33 PM
subford's Avatar
subford
Does the PCM Power relay click when you turn on the key?
Old Jul 25, 2010 | 07:28 PM
SilverFlare92
I verified and yes if i feel that relay while someone turns the key i can feel and hear it click when the key is turned on and also when the key is turned off.
Old Jul 26, 2010 | 06:40 AM
subford's Avatar
subford
Does the Fuel Pump relay click when you turn on the key and click again one second later when it drops back out?
Old Sep 3, 2010 | 01:29 PM
SilverFlare92
Just incase anyone wants to know my computer was bad. Also a 84&1/2 inch belt does not fit when bypassing the smog pump on a 92 351. 83&1/2 does
Eightyfive Flareside
Mar 15, 2015 08:59 PM
Big €ountry
Feb 8, 2015 01:16 PM
BrandonT71
Aug 2, 2013 07:52 PM
guitar_199
Feb 6, 2006 01:29 PM
