CB antenna max height?
Old Jul 24, 2010 | 03:01 AM
LCAM-01XA's Avatar
LCAM-01XA
I need to put a new antenna for my CB, complication is I got a large slide-in camper and the mount for the antenna is good 10ft above the road. From this point up I could use a 4ft whip for an overall height of 14ft that would make me about as high as a tractor-trailer, which could be a problem in some back country roads with low-hung power lines - what would happen is the stainless steel whip touches said power lines? I have no anti-static grounding straps hanging from the truck chassis to the road, so theoretically the truck is insulated from the ground and hitting power lines and such shouldn't be a problem, but is this really the case? Your thoughts on the matter please?
Old Jul 24, 2010 | 07:09 AM
Encho's Avatar
Encho
The Southernmost Mod
If the antenna is flexible you could bend it somewhere near the body or the camper, as they do in some military vehicles. I don't think you'll have any troubles, but i would try to avoid the antenna hitting any charged lines.
Another consideration: do you really need such a tall antenna? maybe you could find a shorter one.
Old Jul 24, 2010 | 07:45 AM
CJM8515's Avatar
CJM8515
3ft and 2ft firestick antennas work really good.
Or like already stated you could bend the whip and secure it like a humvee or something.
Old Jul 24, 2010 | 01:19 PM
LCAM-01XA's Avatar
LCAM-01XA
Oh, bending the antenna would be no problem generally, but I can't be pulling over and messing with it every time I suspect there are power lines or a bridge that are too low... And no, I don't necessarily need such a tall antenna, I've just always been told that to get a good range you want a tall antenna. So a shorter one would good too? Would it be a good idea to have a spring base for the 3ft firestick, so I don't break it in case I do hit something?
Old Jul 24, 2010 | 01:23 PM
wickedklown83's Avatar
wickedklown83
i think what he means is they keep them bent and tied back all the time, not just when they see something in the way
Old Jul 24, 2010 | 01:32 PM
LCAM-01XA's Avatar
LCAM-01XA
And they still work good? What about how antennas are supposed to sit straight up, you know how semi tractors have their antennas angled forward a bot so when they get on the freeway they get straight up cause of wind resistance?
Old Jul 24, 2010 | 02:09 PM
Old93junk's Avatar
Old93junk
I had a telescoping AM/FM/CB antenna on my old Cascade slide in camper, it had a splitter and did double duty as a CB antenna, worked well. all you had to do was open the hatch above the cab-over bed and reach out and raise or lower it.........as long as you remembered to lower it, never a problem going down the road.
Old Jul 24, 2010 | 03:28 PM
lew52's Avatar
lew52
Holey smoke batmam , i don't think its a good idea to hit power wires...
Old Jul 24, 2010 | 03:36 PM
SaikotikGunman's Avatar
SaikotikGunman
I've knocked a few down with hay wagons, no biggie.
Old Jul 24, 2010 | 03:48 PM
lew52's Avatar
lew52
I wouldn't want to follow you !! LOL
Old Jul 24, 2010 | 04:02 PM
CJM8515's Avatar
CJM8515
Could mount the antenna to the mirror.
Old Jul 24, 2010 | 05:00 PM
DBGrif91's Avatar
DBGrif91
Yes, the longer the antenna, the better the range. But how much range are you really looking to get? Firestick antenna's are very good. I have a- that's one, not two- 3' on my semi and I get about a 5 mile range with it.
The direction an antenna is pointing makes little difference. The only thing about tying it back is that the metal from the camper could cause a little interference. But if you have a good CB with signal interference adjustments [noise blockers, calibration, etc.] that interference can be minimized.
Old Jul 24, 2010 | 05:10 PM
SaikotikGunman
Frankly, I prefer not to have anyone following me anyway, unless it's someone I've asked to help out as a chase vehicle. A lot of the roads around here are no winter maintenance goat trails down the side of hills and mountains. I clip far more tree branches and leaning road signs than power lines.
As for the antenna question, to be on topic at least a little... just as there's no replacement for displacement, there's no substitute for a long antenna. The longer the thing is, and the more it sticks up above everything else around it, the better, but that's just one man's opinion.
Old Jul 24, 2010 | 06:18 PM
LCAM-01XA's Avatar
LCAM-01XA
Right, but again there is the fact that I have to pull over, get out of the cab, go in the camper, and mess with the antenna, then on the other side of whatever the obstruction is I gotta do the same thing - I'm not a ham operator or a CB freak, I only use the CB while driving for traffic information and bear spotting - that's why I'm trying to figure out a way to make this work good while on the road without the hassle of messing with it all the time.
Unfortunately no, I cannot do that - my truck is a reg cab so the bed space hangs forward enough to where it's above the windshield too, and even with the wide towing mirrors I have if I mount an antenna there the antenna will be touching camper side very often which I know is very undesirable. If it were a crew-cab truck then you're correct, I'd have the antenna on the mirror and all would be good
I'd be very happy with 5 miles range, with my old 3ft mag-mount I would usually get about 2 miles range so anything over that is an improvement So you suggest a 3ft firestick, and being it's fiberglass even if I catch a power line with it there will be no current flowing to the truck so no danger of electrocution, correct? Would you suggest that I use a spring base for the Firestick, to avoid breaking it in case it catches tree branches?
About the long antenna, say I get a 102" whip and tie it down forward (mount is at the aft end of the camper) but without its tip touching the metal skin, will that work good? What would be a good way of tieing it down, I never really paid attention how the HMMWVs have theirs and there is none of those around here that I can look at.
My CB is just your basic Cobra 19, it has squelch and gain adjustments and that's about it...
Old Jul 24, 2010 | 06:21 PM
CJM8515's Avatar
CJM8515
I got it, mount it to the front bumper. Alot of people who offroad do that and get decent range (3-5 miles).
