won't shift from defrost
Old Jul 23, 2010 | 08:55 PM
hog creek work truck's Avatar
I just got a 1993 f150 the blower works but it won't shift off of defrost the **** on the blower feels like it turns to every notch but doesn,t change the air flow.Is there a common problem with this I should check?
Old Jul 23, 2010 | 09:24 PM
parr4's Avatar
parr4
Defrost is the default position of the system when there is a vacuum leak to the air-direction motor. Check for loose/broken vacuum hose.
Old Jul 23, 2010 | 11:02 PM
Franklin2's Avatar
Franklin2
Your main vacuum line goes through the firewall over on the pass side under the hood. It should go across and hook to the engine or the vacuum tree on the firewall behind the engine.
Old Jul 25, 2010 | 12:24 AM
phurst's Avatar
phurst
Mine had the same problem. Ended up being the little control box the lever connects to on the back of the HVAC controls. This is the thing I'm talking about.
wmbster
Jul 22, 2013 12:08 PM
American Air-1
Dec 3, 2012 09:54 AM
yacn
Aug 15, 2009 11:57 AM
dieingford
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 13, 2004 12:24 PM
f100guy
Dec 5, 2003 12:25 AM
