1993 4.9 cold starting problem?
Old Feb 11, 2003 | 07:59 PM
jetmech8's Avatar
jetmech8
Whenever I try to start my engine after it has been off for several hours and is cold, the first attempt ALWAYS starts then within a couple seconds it stalls.
Then the second attempt it will usually sputter but stay running. Except sometimes when it is very cold it can take 3 attempts.
It will not stay at high (cold) idle very long. Only a couple seconds.
I removed the Idle air control solenoid, disassembled and cleaned the shaft with carb cleaner and reinstalled.
That appeared to cure the problem. Fired right up on first attempt, and high idled real nice for 30 seconds or so, but after only 2 days I'm back to 3 attempts on a cold start to get her to stay running.
I run regular 87 octane.
Any idea's what I can try to fix my problem ??
Thanks for your time.
Old Feb 11, 2003 | 08:03 PM
steve83's Avatar
steve83
Buy a new IAC. I'm in the same boat, but I'm too lazy to do it right now because it hasn't gotten bad enough.
boehmtrent
31
Jan 24, 2015 05:55 AM
wjjarvis84
Oct 4, 2012 11:01 AM
LFDavidson
18
Apr 15, 2010 11:37 PM
tortoise_486
1983 - 2012 Ranger & B-Series
22
Aug 28, 2009 06:45 PM
Diesel-Fanatic
Jan 4, 2009 07:05 AM
